- Dirk
- Been thanked: 3 times
Guys, you can read all about the soda blasting thing in my latest project update here:
http://djb.co.za/project_christn/have_a_soda
`68 Beetle
`66 Fastback
'90 Sunpacer
`68 Beetle
`66 Fastback
'90 Sunpacer
- Ruann007
- What model do you have?: 1970's odd buggy
- Facebook: Ruann Kotze
Stared at my Master Cylinder for hours.... Its a thing of beauty... Actually was trying not to work. Brought the damn thing with me with the hope of going to a spares shop to go get the right kit to fix it with as the one I bought on the w/end doesnt want to fit... Cant understand why though.
A car for the people, an affordable Volkswagen, would bring great joy to the masses and the problems of building such a car must be faced with courage.
Adolf Hitler
Adolf Hitler
- dsan
- Twin Port
busy day, headed out and first stop the accelerator cable decided to snap. R500 tow later and a few choice words, 2 hours of time and loads of dirt, we have a working setup again.
Was going to give it a service, but struggling to find anyone down in Durbs who have the gaskets for the sump in stock, the usual suspects dont.
Daniel
- dablakmark8
- What model do you have?: rat 66/67
today i fixed the numberplate light..damn it works now.DId some welding and repaired the fronseats.reinforced and tackwelded frame.Also repaired the accelerator metal pedal.Its on now and works great.The marvels of engineering.
opened the footwell air vents and closed them.They work great.looks kinda like shard fins.Idid you guys know you have airvent at your feet
The only good answer is the one that destroys the question.It takes a nation of millions to hold us
- CooP
- Clutch
- Has thanked: 13 times
Hey Dirk, thanks for sharing the soda idea. It's brilliant - I can't wait to try it.
Size does matter
- karmakoma
@ dablakmark8
I think you are referring to the footwell heater vents. They work great in Winter yes.
- Dirk
CooP
Before you try it there are a few things you should know.
1. You'll need a lot of Bicarbonate of soda. The shops sell them in 500 gram packs but you plow through that in seconds. So try to work on a big sheet of plastic so you can re-use it as much as possible.
2. It makes a hell of a mess. Don't do it indoors.
3. Although it's safe for the environment and yourself to use, you absolutely have to wear a breathing mask, else everything will taste like soda for hours.
`68 Beetle
`66 Fastback
'90 Sunpacer
`68 Beetle
`66 Fastback
'90 Sunpacer
- davetapson
- What model do you have?: Type 1's '63 and '66
- Facebook: www.facebook.com/davetapson
There must be commercial suppliers who'll sell you a 25kg bag for the same price as four boxes from the supermarket?Dirk wrote:CooP
- hitlers revenge
- Been thanked: 36 times
Try somewhere like "CHIPKINS" bakery supply people.
Maybe "McAdams" bakery supply can help too.
My 5c.
My 5c.
- Farhaad
- Been thanked: 2 times
so am i getting this right.
1) u need lots of bicarb
2) compresor with sandblast gun (can u use the gun with the bottle attached to it, usually used for engine cleaning?)
3)open ventilated space
then
put bicab (dry) in bottle attached to gun and compresor and spray on desired surface?
the result is cleaner than acid bath?
then
- windtramp
- What model do you have?: '72 1600
glued foam to air control plates in ventilation box, re-assembled the unit and installed it ... BLISSS no more cold air "blasting" in thru the dash airvents at 0630 in the morning !!
also reglued foam to those flat plates/valves in the floorwell vents, reassembled the cleaned, repainted re-foamed contraption, and installed back in car .. magic .. no more frozen feet either.
if i cant get the heater to work i can now at least keep the cold air out .. progress
If you're not living on the edge; you are wasting space ..
Started sanding SP steering wheel, masked it off nicely so that now I can send it off to be sprayed , still deciding on a colour. Got my rockers back from the sandblasters early on, unfortunately it's freezing in my garage and I have no guts to work in there until I get the heater sorted
- karmakoma
Had my garden engineer/ ACVW restorer in training very carefully clean the doorpanels and seats of the 58 with some diluted handy andy and a soft cloth.
Checked it when I got home, tough to see in the dark, but at first glance, they look pretty good!
Door panels look 20 years old again!
- Has thanked: 36 times
- Been thanked: 50 times
cleaned out the jets again today and decided "screw it" and drove her to work..............damn it's cold, I need gloves.
Was freaking awesome though.
