Page 52 of 104
Posted: Mon May 31, 2010 12:49 am
by Dirk
Guys, you can read all about the soda blasting thing in my latest project update here:
http://djb.co.za/project_christn/have_a_soda
Posted: Mon May 31, 2010 3:10 pm
by Ruann007
Stared at my Master Cylinder for hours.... Its a thing of beauty... Actually was trying not to work. Brought the damn thing with me with the hope of going to a spares shop to go get the right kit to fix it with as the one I bought on the w/end doesnt want to fit... Cant understand why though.
Posted: Mon May 31, 2010 3:58 pm
by dsan
busy day, headed out and first stop the accelerator cable decided to snap. R500 tow later and a few choice words, 2 hours of time and loads of dirt, we have a working setup again.
Was going to give it a service, but struggling to find anyone down in Durbs who have the gaskets for the sump in stock, the usual suspects dont.
Posted: Mon May 31, 2010 6:12 pm
by dablakmark8
today i fixed the numberplate light..damn it works now.DId some welding and repaired the fronseats.reinforced and tackwelded frame.Also repaired the accelerator metal pedal.Its on now and works great.The marvels of engineering.
opened the footwell air vents and closed them.They work great.looks kinda like shard fins.Idid you guys know you have airvent at your feet :flash:
Posted: Mon May 31, 2010 10:41 pm
by CooP
Hey Dirk, thanks for sharing the soda idea. It's brilliant - I can't wait to try it. 8)
Posted: Tue Jun 01, 2010 12:18 am
by karmakoma
@ dablakmark8
I think you are referring to the footwell heater vents. They work great in Winter yes. :wink:
Posted: Tue Jun 01, 2010 12:58 am
by Dirk
CooP
Before you try it there are a few things you should know.
1. You'll need a lot of Bicarbonate of soda. The shops sell them in 500 gram packs but you plow through that in seconds. So try to work on a big sheet of plastic so you can re-use it as much as possible.
2. It makes a hell of a mess. Don't do it indoors.
3. Although it's safe for the environment and yourself to use, you absolutely have to wear a breathing mask, else everything will taste like soda for hours.
Posted: Tue Jun 01, 2010 10:55 am
by davetapson
Dirk wrote:CooP
There must be commercial suppliers who'll sell you a 25kg bag for the same price as four boxes from the supermarket?
Posted: Tue Jun 01, 2010 8:07 pm
by hitlers revenge
Try somewhere like "CHIPKINS" bakery supply people.
Maybe "McAdams" bakery supply can help too.
My 5c.
Posted: Tue Jun 01, 2010 8:32 pm
by Farhaad
so am i getting this right.
1) u need lots of bicarb
2) compresor with sandblast gun (can u use the gun with the bottle attached to it, usually used for engine cleaning?)
3)open ventilated space
then
put bicab (dry) in bottle attached to gun and compresor and spray on desired surface?
the result is cleaner than acid bath?
Posted: Tue Jun 01, 2010 8:39 pm
by windtramp
glued foam to air control plates in ventilation box, re-assembled the unit and installed it ... BLISSS no more cold air "blasting" in thru the dash airvents at 0630 in the morning !!
also reglued foam to those flat plates/valves in the floorwell vents, reassembled the cleaned, repainted re-foamed contraption, and installed back in car .. magic .. no more frozen feet either.
if i cant get the heater to work i can now at least keep the cold air out .. progress 8)
Posted: Tue Jun 01, 2010 9:38 pm
by Blitzkrieg
Started sanding SP steering wheel, masked it off nicely so that now I can send it off to be sprayed , still deciding on a colour. Got my rockers back from the sandblasters early on, unfortunately it's freezing in my garage and I have no guts to work in there until I get the heater sorted :oops:
Posted: Tue Jun 01, 2010 9:49 pm
by karmakoma
Had my garden engineer/ ACVW restorer in training very carefully clean the doorpanels and seats of the 58 with some diluted handy andy and a soft cloth.
Checked it when I got home, tough to see in the dark, but at first glance, they look pretty good! :hangloose:
Door panels look 20 years old again! :mrgreen:
Posted: Wed Jun 02, 2010 10:01 pm
by lowlight
Pick up the 67 today :D
Posted: Thu Jun 03, 2010 10:35 am
by flatfourfan
cleaned out the jets again today and decided "screw it" and drove her to work..............damn it's cold, I need gloves.
Was freaking awesome though.
