Page 58 of 104
Posted: Fri Jul 09, 2010 3:53 pm
by hitlers revenge
!@#$%%$#$%^%^% Took mine down to the harbour to get covered in Soda Ash !@#$%^^^%$#^$%#
Guess what I'll be doing the weekend.
Posted: Mon Jul 12, 2010 3:07 pm
by lowlight
Got a valve to make a pin for the fuel pump for my beetle.
Posted: Mon Jul 12, 2010 3:08 pm
by Blitzkrieg
Couldn't find a buyer for the project so it's on again
Posted: Mon Jul 12, 2010 5:16 pm
by jmvv
Put Petrus on the stretcher and towed him to Vee Motors, so they can sort out the following issues under warranty:
Burnt valve on no 4
Oil leaks - third attempt (He piddles like a Jack Russel puppy)
Loss of oil pressure as engine warms up - caused by second oil leak attention attempt.
I know that I will eventually rebuild the engine myself, but a warranty is a warranty...... and sofar they have been very decent about the issues.
PS:
Sofar I haven't tossed my toys out the cot. Maybe it's too cold to get angry.
Posted: Mon Jul 12, 2010 7:59 pm
Blitzkrieg wrote:Couldn't find a buyer for the project so it's on again
make up your mind please....
Posted: Mon Jul 12, 2010 8:17 pm
by Hloni
Thought since I am in GP I should maximise and visited VS Jetpark and got Ol' Betty a set of Bougis and tapet cover gaskets.
Can't wait to install the Bougis next month when I get home.
Thanx Martin for the service.
The bearded man.
Posted: Mon Jul 12, 2010 9:20 pm
by CooP
Finally finished off the filling in of the (unused) left-hand sliding door handle. It's gone from this:
Which warped a lot of the door when it was welded, even though we just did a bit at a time to try and avoid overheating it. I have been laying on lots of thin layers of filler every day after work and then block-sanding them back again. During this laborious process:
And it is now looking like this:
Also made a start on the mess that is the front end, pics to follow. Whew, time for some
Posted: Tue Jul 13, 2010 8:06 am
by BUSBFK
I changed the thing between the gear shit rod and the gear box on Flossie now her gear change is nice and tight again.
Posted: Tue Jul 13, 2010 8:44 am
by Blitzkrieg
Tony Z wrote:Blitzkrieg wrote:Couldn't find a buyer for the project so it's on again
Don't worry this time I'm decided and sticking to my guns
Posted: Tue Jul 13, 2010 8:50 am
by CooP
BUSBFK wrote:I changed the thing between the gear shit rod and the gear box
Gear shit rod
That's what it
should be called
Posted: Tue Jul 13, 2010 9:16 am
by BUSBFK
CooP wrote:BUSBFK wrote:I changed the thing between the gear shit rod and the gear box
Gear shit rod
That's what it
should be called
Yes shit rod.
Cause it kept me up until 12 last night. And after that the new baby did his part in keeping me up even more.
Posted: Tue Jul 13, 2010 10:50 am
by splitfan
I guess it is what it is , although not perfect its a once off and therefore a "Marmite" moment you either like it or you dont
Posted: Tue Jul 13, 2010 11:08 am
by dsan
about to set fire to this bug. Seriously I will never buy parts made in brasil again. They are so poor in terms of quality and build, you are wasting your money. piece of s*** f*** wan*** carb now will not disable the choke, so it runs like s***.
worked fine all week but the day I really need it, it happens.
bah!
Posted: Tue Jul 13, 2010 12:52 pm
Blitzkrieg wrote:Tony Z wrote:Blitzkrieg wrote:Couldn't find a buyer for the project so it's on again
I am sure you said that last time....
Posted: Sat Jul 17, 2010 6:34 pm
by hitlers revenge
With the Help of Ron (all they way in PNG) I pulled one of my busses reduction boxes apart. Are they supposed to be full of grease? Why then have they got Oil fillers and drainers?????????
Removed the barn doors and serviced the hinges. In the process loosing one of the plates which the countershunk bolts bolt onto. The plate fell down the vertical channel. Had to cut a hole in the channel and make up a new plate. !@#$$%^%%$##@@
