Page 7 of 9
Help rescue a Bay Camper - please
Posted: Sun Jan 22, 2012 8:26 pm
by didi
Here is a better photo of the Box I made to house the oil filter
Posted: Sun Jan 22, 2012 8:29 pm
by didi
I used some high density foam to make a engine seal similar to the type IV. Do you guys think it will work?
Posted: Tue Jan 24, 2012 7:43 pm
by didi
The Westy had a flower attack on the drivers side
Posted: Sun Jan 29, 2012 10:46 pm
by didi
Made a new panel for the rear hatch. It had rotten pieces of wood attached with rusty old screws.
I made a template with cardboard and then traced it on masonite. I then used the foam and material to cover it. Here's the end result:
Posted: Mon Jan 30, 2012 10:07 pm
by didi
Installed new poptop roof toggles tonight
Re: Help rescue a Bay Camper - please
Posted: Mon Jan 30, 2012 10:14 pm
by jolas
Hi Diedrich, I like that bracket in the second photo, I don't have complete faith in the originals, have had one or two scary experiences in the past.....
Did you make it up yourself or are they readily available over the counter ?
Cheers
Posted: Wed Feb 01, 2012 11:13 pm
by didi
Jolas, I brought the kits in from the bus depot in the USA when I ordered a bunch of stuff. The packaging they arrived in, is from Justkampers in GB.
I used my old metal pieces and just replaced the rubber part. I have never driven with a poptop. What is so scary? Does it want to become airborne?
I put my new valid license disc on the front window tonight, and put the number-plates on the bus.
Posted: Thu Feb 02, 2012 7:30 am
by didi
I got to insure the bus because it's going to start running on the road. Do I do a 3rd party, fire and theft? How would I know what the replacement value is?
Posted: Fri Feb 03, 2012 9:35 pm
by didi
The Westy at Dirk's workshop
Posted: Fri Feb 03, 2012 9:57 pm
by jolas
My 2 roofmounted hinge/brackets became quite worn over the years with the result that the roof would rise slightly, especially when a bus or truck came passed from the opposite direction. I also did'nt have the rubber seal that wraps around the sides and front of the roof, always found that to be quite ugly. Anyway a truck came passed me from the front on a narrow road one day and the roof did lift off, broke away from one of the bracket/hinge thingys, did'nt fly away though as the canvass kept it back. Had a hell of a fright though. The car behind me nearly left the road as well, probably anticipating the roof coming clean off.
Made 2 new hinge brackets, replaced the seal, but I'm not happy with the original internal fasteners.
Some westys have a "hook" mounted on the front of the kombi's roof (under the fiberglass roof, can't be seen unless you look under the fiberglass roof), when you lower the roof, it makes contact with another fastener which prevents the roof from lifting from the front - will try find some pics. Easiest way to check on your bus is to look for 2 rivet heads on the front/middle area of the fiberglass roof (i.e just above the windscreen).
Replacement value : I regularly save ads on Gumtree for later reference, and work out an average value from that - or even better, check out the classifieds in Volksworld or Just Campers
Congrats on getting your bus on the road Didi
Posted: Mon Feb 06, 2012 5:25 pm
by didi
jolas wrote:Hi Diedrich, I like that bracket in the second photo, I don't have complete faith in the originals, have had one or two scary experiences in the past.....
Cheers
The latch in the first photo are the ones that latch on from the side. The 2nd photo is the middle rear latch. I do have that metal front clip on the roof, but it is not lining up properly
Posted: Tue Feb 14, 2012 7:20 pm
by didi
Dirk is helping me with the final touches to get the bus ready for the campout. The brake lines are replaced as well as the wheel cylinders. The small electric quirks are also sorted out. Tomorrow it's the tierod ends and then it's all done.
Posted: Tue Feb 14, 2012 7:55 pm
by jolas
You need to change the heading of your thread to something else e.g "Saved bay camper" or "Rescued bay camper", etc, etc
It has been great following the progress of this bus didi, right from the story of purchase up till now
Posted: Thu Feb 16, 2012 11:28 am
by didi
Maybe one of the moderators can change the heading. I cannot change it.
Here is a picture of the beetle tie rod that was on the car
Lots of play on the shaft and the tread stripped!
Some desperate calls last night and beetlefanatic came to the rescue with a tierod!
Thank you so much Bernard!
I drove my bus home last night from Dirk's workshop (driving it for the first time since I got it)
Dirk did a fantastic job with the brakes. It was well worth it.
Still a few things to do (is it ever done)
Posted: Fri Mar 02, 2012 7:13 am
by didi
I installed a voltmeter and engine temp meter last night. The voltmeter is working, but I still need to mount the temp sensor in the engine. I thought of using the block off plate on the universal case where the type 3 dipstick sits.
ok, and align the temp gauge to sit straight
I am also thinking of fitting a rev counter, as I cannot hear the engine over the whining gearbox.
