I done the toe in today and spaced the front wheels due to a scraping sound which turned out to be the tie rod scraping against the edge of the rim.
Took some more pics of my garage queen.........
My Project beetle - wish me luck !
- Oil Seal
- Has thanked: 13 times
- Been thanked: 9 times
- Has thanked: 193 times
- Been thanked: 121 times
- Oil Seal
Re: My Project beetle - wish me luck !
thanx Terry
So no more scraping issues with the small wheels , may need to get longer wheel studs due to the 6mm spacers inserted just for peace of mind.
Rear shoes have been adjusted , handbrake works. To tell you the truth the brakes dont feel much better than what they were previously with the old drum system. I have bled the brakes twice already and the pedal is hard.
My turning circle is also wider,,,,
I wrapped the exhaust today
- What model do you have?: 1600 S & Oval
- Been thanked: 2 times
Is the type 4 in? Sorry I'm asking now only but for some reason I cannot view all the pictures as it only presents a tiny icon saying image...
And if so, did you go the upright conversion or do a straight swap with bodywork effort?
...low n slow...
- Oil Seal
Im running a single port beetle engine at the moment, ended up sticking that 1700 type 4 into a kombi.
