Well the beat goes on
Sanding sanding and then some more sanding
Note to self - its all going to be worth it when that red goes on
I am really lovin these lines
Have got most of the primer down to 600 grit
some small places that need a little patching
Started the repair to the nose section
Years of being towed down dirt roads has taken its toll on the front of the nose - seriuos sand blasting with the fine gravel
Some tears in the lower lip - so out with the resin and some matting to seal it all up again
Rough sanding and then filled with some boddy putty
Played around and made a little "Wheels of Fortune " mobile
To date it has not worked as I am still broke after the Christmas season - January is a seriousley LONG month
This morning decided to clean the wiper motor and assembly up
Stripped all down cleaned and greased - now working like never before
Had a little wobble when putting back the two skrew holders on the motor as they kept on falling in and then getting stuck on the magnet
Then all apart again to get the bugger out - fiddle with the bushes and then again the little shit would fall in and get stuck inside
After the 4th assembly and the same happened the whole lot nearly got tossed
Used my noggin and held the thinggie with a nose pliers - all sorted
Quite like this
Well heres to a fun filled weekend of some more sanding and maybe some paint
