chrisradioman
Post by chrisradioman »
How the switch looks in the dash, its a proper Hella one but it doesn't look as good quality as the original VW one.:-
Fouth coat:-
Fith coat:-
sixth coat:-
Put this on so the rain doesn't get into the cavity:-
Sixth coat:-
Seventh coat:-
Looks like I put too much on It needs another one now, the paint is so thick I marked it by opening the lid doh!
I'm going to put it in the oven now at 60 deg C to bake it off, when it cools, I'll sand it & give it a light dusting just to put the sine back:-
chrisradioman
Sanded all of the high spots off, you can see the low parts are shiny, you sand till its all mat then you know its level:-
Another coat, once dry I realised the paint was a bit too thick around the edges:-
This is now doing my head in, I've decided to split the two parts now as paint is building up to thick in between the gaps, I've now sanded them right back with 240 grit & painted hopefully for the last time:-
chrisradioman
While the wife is in work, place the items on a baking tray at approx 60 deg C for approx 10 mins.
At last I'm happy with the finish:-
Would I do it again no, I was tempted to polish & lacquer it, if I had to do it again I would either do that or Powder coat it. :)
chrisradioman
All back together, puzzled by the swirl marks in the photo, I can't see them with my eyes.
Not happy with those swirls so just flatted it wet with 1500 lightly dusted it & baked it in the oven, looks good again, I'll photo it next when fitted.
chrisradioman
Its back on now:-
chrisradioman
Some pictures from Yesterday, Gnol Park in Neath S.Wales:-
chrisradioman
Decided to follow a night event rally last night, we went to the scruteneering & the first spectator point, good fun & I'd gladly go again.
We had a Pot Noodle while waiting for the first car, how civalized is that lol:-
chrisradioman
Finally got around to sorting the videos I took at Brands Hatch:-
chrisradioman
chrisradioman
My Buddy seat & centre seats are now powder coated in primer & ready for paint:-
chrisradioman
Got a few Busfest aerial pics off their Facebook page. Milly is in all of these but you'll need to zoom in to see them:-
Were on the bottom right field in the first picture.
chrisradioman
Got a few screws ready to fit the counter top & the power outlet:-
The Power Outlet is now on properly with new shiny screws:-
chrisradioman
Scored an awesome proper retro looking battery voltage indicator of a top guy on The Late Bay called bernjb56, thanks pal:-
Its made in the USA by a firm called Golden Eye, You can check both batteries by flicking a switch. :)
chrisradioman
Got myself a set of retro 70's style chrome Spotlights for the front of Milly, I just got to work out now how to fit them without drilling holes:-
Well it my youngest's birthday today, she's 1. Time has gone fast, here is Alys 2 days old last year:-
chrisradioman
Didn't get much done today as I had to help organize little Alys's birthday, but I did fit the spot lights fitted.
I checked the underside of the bumper & there were 4 holes already drilled, The spotlights would fill 2 if I turned the bumper over but the other 2 would be just there:-
Quite a few dead fly's on Milly's front panel:_
Measured up the locations & put masking tape so I could mark the exact location:-
Got my trusty combi dril out with a 5.5mm drill bit:-
Drilled the hole, you can see I put a booklet underneath so the drill wouldn't touch Milly's paint:-
Drilled the hole out to 10mm:-
Used some 17mm lock nuts so they wo't vibrate loose:-
Ankor waxe'd the hole to stop it from rusting:-
Bolted the spots on:-
