gave the buggy a thorough serch for loose nuts and bolts as it seems the engine and gearbox want to fall out when driving on a not to smooth road.
After checking every thing from engine and gearbox mountings, starter, alternator, you name it I checked it.
Eventually with the help of my son doing short pull aways in the driveway I found the silencer welding had rusted through. Now when I drive I have to pray that it doesn't fall off and fly into the car behind me. :oops:
Anybody know a welder :D
Dappermuis
Post by Dappermuis »
Ok so here is the list
Last week Sunday:
Rewired the whole interior of the car, removed old fuse box, replaced with new blade fuse one.
Took out dash board, cleaned it and resprayed the metal pieces
Today:
Drained gearbox oil, refilled
Fixed worn out speedo cable at the hub, working now for the first time since I've bought the Kombi
Adjusted hand brake cable
Installed radio head unit.
Made a little something out of Delrin
any guesses what this is?
RICKY-R69
Post by RICKY-R69 »
Custom made oil filler cap?
IMPI
What model do you have?: sp2
Been thanked: 78 times
Post by IMPI »
Hi Tony
Is it A piston pin button?
I wish I could get enlightened on those things
I have tried Aly busted within 3000km
Then tried brass didnt work
Then teflon didnt work
So far my opinion of those things: They suck
It seems they cant do the distance and there is also wear marks in the cylinder where the cross hatching is plished or the pin wears a huge chunk out of the cylinder
I see you are trying delrin Care to elaborate?
clue - its about the same size as a cam follower/lifter
IMPI
Post by IMPI »
How stupid of me
Its a distributor delete plug
A person asks for dizzy dimensions and then makes a nice part LOL
IMPI wrote:Hi Tony
Empi - no it isnt a button. I have used the Empi teflon buttons in my 2332. They seem to work. Wont open the engine to find out tho.
I think the trick with the buttons is to fit them snuggly into the gudgeon pin and make sure the pin can still move a tad, maybe 0.5 to 1mm. That way they dont press on the cylinder walls. I see them being advantages by keeping oil out of the pin and thus making things a little lighter.
Why delrin - cause I am on a boat floating in the Mediterranean and the only other material I have that size is wood. Would have preferred aluminium but I dont have.
IMPI wrote:How stupid of me
The penny drops. LOL
1 beer for Armand if we ever meet.
CooP
Post by CooP »
I did some more sandpapering, as usual :jerkoff:
but BUSBFK came over and fixed my busted passenger door :bowdown:
now opens and closes like a good 'un, thanks mate
Size does matter
BUSBFK
Post by BUSBFK »
CooP wrote:I did some more sandpapering, as usual :jerkoff:
Pleasure i might just drop in again for lunch and n cold one or two. :twisted:
MELLO YELLOW
Post by MELLO YELLOW »
Drove my bug today :D first time in six weeks :oops:
Even if it was only to fill up with juice
What a feelling
Started my Westy on the weekend :hangloose:
lowlight
Post by lowlight »
Drove the westy to work today. :D
CooP
Post by CooP »
Nice one Lowlight! I can't wait for the day that I can write that in here...
Size does matter
Donovan D
Has thanked: 150 times
Been thanked: 73 times
Post by Donovan D »
Fitted my safari windows(finally)
Story time:
After taken the safari frame to a certain P(something)-Glass on Tuesday and being told they will inject the frame with poly-urethane and insert laminated safety glass into it, I could come and collect next day at 09:30 sharp for R350. So Wednesday I was busy at home and around 14:00 decided to phone them up, so the guy told me they are waiting for the poly-urethane to dry ,best would be to collect Thursday because if the window was to break they could replace it no charge. So I went there this morning, the guy I dealt with was not there, got the frame with loads of black silicone around the edges. some of it didnt event come close to the frame just neatly splattered on the window :roll: :roll: so I start tearing it off, I ask the guy are you sure theres something between the glass and the frame and he ensures me there is.Go to the counter to pay, the guy takes out his tape and measures, says R150 ??? R200 less than original,
Got home and started fitting the frame but for some reason it wouldnt go into the window of the body, after a few minutes I noticed that the one corner was hitting the edge of the body frame, So I took the frame apart to rectify. And as I thought, there was nothing between the glass and the frame, the glass was pushed in and the frame screwed together with a very piccaso like display of silicone, What a bunch of :jerkoff: 's
They wont be seeing me ever again
