Anyway, last night I started her and instantly noted that there was a huge problems. She didn't want to idle and the oil pressure did not want to build up.
So I do what any ACVW owner would do... check the oil. Strangely the dipstick read WAY ABOVE FULL. And I mean WAY ABOVE.
After this I decided to park her in the garage over night and check again in the morning.
This morning I checked again, and the dipstick still read way above full. So I decided to tap the oil out and see how much I get out.
Slowly I unscrewed the sump cover and the moment the oil started flowing I knew exactly what happened. The sudden smell of fuel was unmistakable.
It would seem that sitting at the incline she was, the fuel slowly leaked past the fuel pump into the sump.
I completely drained her and allowed time for the fuel to evaporate. I made use of this time by doing the valve adjustment and having quite a bit of coffee.
Now, with fresh oil and valves adjusted, she idles and runs... but still overheats.
