Bodyfiller advise
Div
What model do you have?: 1971
Bodyfiller advise
Post by Div »
When sanding bodyfiller to prep for paint must the surface be smooth without fine scratches or can the scartches be visible. Will paint not fill fine scratches. Any help
IMPI
What model do you have?: sp2
Been thanked: 78 times
Re: Bodyfiller advise
Post by IMPI »
Normal practice is to sand with p36
then p80
then p180
Then use MS primer
sand with 220 next coat of MS
then go down progressively to a minimum of 800 if you want a really good job
The trick is to allow ample drying time between different coats I would reccomend the car stand in primer for at least 3 weeks before final sanding as primers and putties shrink somewhat before finally drying this causes those annoying scratches you see in some paint jobs
