New Project for the new year by new member :)
- sarel.wagner
- Pushrod
- What model do you have?: T1 x 4, Split SCwide
- Facebook: http://www.facebook.com/sarel.wagner
- Been thanked: 2 times
Re: New Project for the new year by new member :)
What other people think of you is none of your damn business
- sarel.wagner
- Pushrod
Now the real work can begin
More Hi-Res pictures here: http://www.flickr.com/photos/sarel_wagn ... 726078321/
Rgrds
Rgrds
- sarel.wagner
- Pushrod
Hey forkit "SOME" progress is better than none Just the steering wheel missing and a few other bits, so I guess it's a dragster, can only go straight
Rgrds
Rgrds
So what is wonngg with the Joy stick in the middle
- sarel.wagner
- Pushrod
- sarel.wagner
- Pushrod
Phanx CooP
I started using the spit last nite, works lekker, much happiness. I can position it perfectly and work standing up or sitting down. If anything it may be a bit on the high side when turned upside down 180deg, but that will onnly be for painting. Its only metal tho.... so may cut and weld it later.
Only the safety pins to do still, and then paint.
Rgrds
Rgrds
- sarel.wagner
- Pushrod
- Farhaad
i was starting to wonder what the new project was.
workshop or a custom beetle
nice toys
nice toys
- sarel.wagner
- Pushrod
Phanx bro, its a bit o both Getting there on the Beetle part now, about time too Plasmacutter works bloody well wish I had a steady hand..... maybe have a look see into the brandy bottle before I break out the plasma next time tho Just fopr a steady hand of courseFarhaad wrote:i was starting to wonder what the new project was.
nice toys
Rgrds
- sarel.wagner
- Pushrod
Got these bad boys in today and some other painting stuff too....
Anest Iwata LPH400 Base gun Iwata W400 Clear gun DeVilbiss Air Supply full face mask Rgrds
- sarel.wagner
- Pushrod
New upgraded 8mm fuel hard line installed and fixed in place with original tabs crappy job at best, especially the thicker 8mm line!
Updated the build blog as well http://konzeptdrei.blogspot.com/2012/07/bugdate-15.html
Done!
Nice one Sarel... Keep them coming.
- sarel.wagner
- Pushrod
Thank ya Tony Doing some Electrolytic de-rusting on the fuel tank Yes the inside of the tank..... See here http://konzeptdrei.blogspot.com/
Rgrds
Rgrds
