TRANSVERSE MOUNTED ENGINE IN BAY
Posted: Thu Aug 12, 2010 1:29 pm
by RICKY-R69
Hi Guys
Do anybody know if it was ever attemted to fit a golf engine and gearbox transversely into a bay kombi? How difficult could it be?
Re: TRANSVERSE MOUNTED ENGINE IN BAY
Posted: Thu Aug 12, 2010 1:43 pm
by calooker
Seen several, v6 & v8 with difs as well as a 16v golf in a split bus, all midmounts.
Posted: Thu Aug 12, 2010 1:45 pm
by Barry
Cut front off Golf, cut guts out of bay, wheel golf front under bay & weld, tie up the steering solid(you did want the engine in the back right?) and you're good to go.......
Posted: Thu Aug 12, 2010 1:53 pm
by RICKY-R69
something like this.
Posted: Thu Aug 12, 2010 1:56 pm
by CooP
http://www.vwkd.co.uk/ has loads of info about similar conversions.
Posted: Thu Aug 12, 2010 3:24 pm
by Sambabus
I would like to be the first to ask you please please dont do that to youre bus,its not an easily reversably conversion and it doesnt look nice,....
Posted: Fri Aug 13, 2010 8:04 am
by DDunc
Yes please don't.
Then its not an ACVW anymore
Posted: Fri Aug 13, 2010 8:59 am
by Blitzkrieg
I know of someone who will be doing a Subaru midmount conversion in a split D/C.
Now that promises to be a beast
Posted: Fri Aug 13, 2010 9:54 am
by RICKY-R69
I am not planning to do that to my bus. Just wondered.
Posted: Fri Aug 13, 2010 1:12 pm
by RICKY-R69
But if I don't find a gearbox soon I just might have to!
Posted: Sun Aug 15, 2010 9:49 am
by BARON
Put it all on a subframe and bolt it to the existing chassis
Idont think it’s a good idea. You will have to do a lot of cutting. The bay engine bay will be big enough but the roof is to low.
.You will also will loose weight balance as the transverse engine will have a lot of weight high up. You will need to remove the spring plate/swing arms and install a Mc Pherson type suspension.
You will be much better of using a Subaru or rotary engine ---much easier fit and enough power
Then there is the roadworthy certificate issue. It will never pass in my area as you are not allowed to weld on suspension parts
This guy did it on a plastic Porsche and although he didn’t used a vw pan that chassis operated exactly like the vw rear end .
Ten when you are finished you have to deal with this
Cheers baron
Posted: Sun Aug 15, 2010 10:13 am
by Pine
Toyota engines in Porsche?
I think we have to start accepting it:
