Lowering the rear torsion bars...a guide for the newbs...
Posted: Sun Dec 17, 2006 12:18 pm
by Merlin
Posted: Sun Dec 17, 2006 12:36 pm
Brilliant... :!: :!: :!:
that was published in Volkworld a few years back, but dont ask me which issue it was
Posted: Sun Dec 17, 2006 9:15 pm
by hitlers revenge
Hi Tony
What does the chart mean when it says - spring plate 10 degrees or spring plate 20 degrees
Posted: Sun Dec 17, 2006 10:12 pm
The rear spring plate is attached to the splined shaft. The shaft has splines on both ends, but a different number on each end. This allows very fine adjustments of the ride height.
As you can see, if you drop the rear by one spline only on the inside, you get a 9deg drop or 6cm. 9 deg is the amount the spring plate will change by (9 deg upwards...)
