Page 1 of 2
My Purple Monster
Posted: Thu Oct 21, 2010 9:06 am
by Dkhum
Hello "Airheads". I am excited that my project is back on track again. I bought a beautiful 1972 purple Beetle with a genuine leather lilac interior to go with. However, the seller said the engine had seized. Upon removing it and stripping it, it turns out a conrod cap screw failed and came apart, hence the engine would not turn. There is no hole on the casing. I don't know yet if the casing can still be used. It is a 1300. Assuming the casing cab still be used, is it worth all the machining to make it a 1600 or must I just look for a 1600 motor?
Re: My Purple Monster
Posted: Thu Oct 21, 2010 9:20 am
by slak
nice pics please
u only need to machine the heads bigger
just make sure the valves are 35.5 in and 32 ex
and u should have no other problems making it 1600
by just changing the sleeves
Posted: Thu Oct 21, 2010 10:43 am
by calooker
Use what you have and build it up, at least you know what you getting.
Posted: Fri Oct 22, 2010 12:36 pm
by Dkhum
The monster broke a conrod on the crankshaft end, piston 3 and dragged the cap right round until it jammed. Is there a likelyhood that the crank could be bent? Must I worry about the parts of the case that got scored in the process. Gentlemen, the case is so beautiful, it is not funny. Standard mains, standard big ends and no wear on the rear main seal area. I really want to use this casing.
Posted: Fri Oct 22, 2010 12:51 pm
by slak
go to a engineering shop let them check it out for straightness
but have the block checked out properly by someone that knows
beetle engines it might have warped
Posted: Fri Oct 22, 2010 1:02 pm
by Dkhum
Could you please steer me to a reputable engineering co around the edenvale & Isando area.
Posted: Fri Oct 22, 2010 1:15 pm
by slak
only people i know there is volks engine change
011 452-7352/3
127 10th avenue
edenvale
Posted: Fri Oct 22, 2010 1:32 pm
by Dkhum
Hi Oil stain. Thanks for the info. Volks Engine says I must expect to pay a max of R350 to have the crank crack tested and the casing visually examined. Is this right?
Posted: Fri Oct 22, 2010 2:11 pm
by eben
Posted: Fri Oct 22, 2010 2:55 pm
by slak
yes drip
Posted: Fri Oct 22, 2010 7:35 pm
by bugspray
What's so funny Site Admin???
Posted: Fri Oct 22, 2010 8:02 pm
Dont know tranny, trying to figure it out myself
Posted: Fri Oct 22, 2010 8:06 pm
by bugspray
Eish I kinda walked into that one huh!!!
Posted: Mon Oct 25, 2010 10:28 am
by Dkhum
After careful examination, it turns out that one of the lifter bores in the crankcase is cracked. The crankshaft is also bent. Now I need a casing, a set of 1600 sleeves and a crankshaft. Any assistance gladly welcome.
Posted: Mon Oct 25, 2010 11:16 am
by slak
Speak to calooker aka Rui he's got a case speak to him about a price
