Weber Carb Rebuild kits
Get your parts here
Muderick
Has thanked: 42 times
Been thanked: 69 times
Post by Muderick »
Hi Volks
I have 2 sets of genuine Weber 36 IDF Carb rebuild kits. Each kit will service 2 down draught carbs.
They can also be modified to be used on Weber 40 IDF's by using your old top carb gasket as a template and just punching out a new hole for the air jet. Then you just need to change the diaphram to the one found on a Capri's V6 Webercarb. This can be purchased loose from most spare shops.
R800 per set posted anywhere in SA.
Muds
0829941643
Old School or Bust!
Muderick
Re: Weber Carb Rebuild kits
Post by Muderick »
1 set left, posted anywhere in SA
R750
Also 1 set of Dellorto 36 DRLA rebuild kit (for 2 carbs)
R800
Pm or call me
Muds
0829941643
Old School or Bust!
