Page 1 of 4
Theft Prevention
Posted: Mon May 16, 2011 4:43 pm
by 1963
Am I naive or just Capetonian? I've been happily sitting here thinking, "Beetles don't get stolen, they're too old", and then I found this thread, dammit. My Ma drives the '63 and the '72 all round Joburg's Northern suburbs with no gorilla lock, no alarm, and no theft protection of any other kind. What are most of you guys using in Gangster's Paradise?
Re: Theft Prevention
Posted: Mon May 16, 2011 4:49 pm
by fig
I prefer two methods (not saying I have them on my cars!):
1. A simple, hidden ignition cut-off switch that you can fit yourself.
2. A solenoid cut-off on the fuel line at the base of the fuel tank. (This doubles as fire security)
In general, if someone has targeted your car, they'll do whatever it takes to get it. The fuel cut-off allows them to take the car, but it will run out of fuel as soon as the carb bowl drains, which will stop the car, hopefully somewhere that will attract attention, such as in an intersection, and make the thieves abandon it.
Visible security such as steering and gear locks is also good.
Generally, I don't like leaving my car unattended in parking lots, etc, and I try to only park in secure areas or where I can see it.
Posted: Mon May 16, 2011 7:47 pm
by Hloni
fig wrote:I prefer two methods (not saying I have them on my cars!):
2. A solenoid cut-off on the fuel line at the base of the fuel tank. (This doubles as fire security) would this be activated by a remote?
Posted: Mon May 16, 2011 8:36 pm
by fig
Fuel cut-off could be remote operated, but simpler and more reliable would be a hidden switch.
Posted: Mon May 16, 2011 9:04 pm
by Hloni
fig wrote:2. A solenoid cut-off on the fuel line at the base of the fuel tank. (This doubles as fire security)
I just drove my bug from the office home, and I couldn't get my head around this. How would one wire a solenoid so that in an impact it turns off? I get what you said in your response of a switch, however I still cannot get my head to how would it be wired so that when the engine stalls or there is an impact that it cuts off.
I hope I am not asking you to compromise your security
Posted: Mon May 16, 2011 9:27 pm
by fig
Hahaha, nothing so complicated. It's fire security because, on both Beetles and split buses, there is a gravity feed of fuel to the engine because the base of the tank is higher than the fuel pump. I have had the horrifying experience (in my 63 Dormobile) of the bus catching fire and fresh fuel gushing all over hot metal and reigniting (twice!) after putting the fire out. With a fuel cut-off, as soon as you notice an engine fire, you cut off the fuel supply before fighting the fire.
Posted: Mon May 16, 2011 9:34 pm
by Hloni
fig wrote:... With a fuel cut-off, as soon as you notice an engine fire, you cut off the fuel supply before fighting the fire.
Pics of what I might be looking for from my local Midas?
Posted: Mon May 16, 2011 10:27 pm
by fig
I don't have pics. Midas may have, but you'll definitely find one at a car sound and security shop.
Posted: Tue May 17, 2011 7:59 am
by VW-rules
Hloni wrote: I get what you said in your response of a switch, however I still cannot get my head to how would it be wired so that when the engine stalls or there is an impact that it cuts off.
All Land Rovers have an impact cut off switch in the engine compartment. It's nice and easy to reset too and you only need to have it pointed out to you once. You'll never forget it and it will become the first thing you check if it cuts out on you again.
Posted: Tue May 17, 2011 8:57 am
by 1963
Thanks for the input fig, and others. Hmmm, I think for now I'll stick with the stand-by of a gorilla lock - mainly 'cos it's cheap, but also because we're dealing with an 84-year old woman. (Right now, the biggest security is that the '63 can't get out of the garage: the ol' chap next door in the retirement village didn't plug the garage door motor in again after he'd helped Ma recharge the battery ... bwahahaha!)
Posted: Tue May 17, 2011 9:36 am
by swiggs
A steering lock and a gearlock works for me. But like was said earlier, if the creep wants your ride, he/she will do anything to get it.
Posted: Tue May 17, 2011 12:50 pm
by louisvr45
how about put anonther hiddin switch inline with the carb's fuel cutoff valve?
Posted: Tue May 17, 2011 2:06 pm
by fig
louisvr45 wrote:how about put anonther hiddin switch inline with the carb's fuel cutoff valve?
The fuel cut-off on the carb only cuts the idle circuit; it doesn't stop the car from running.
Posted: Sat Jun 18, 2011 8:19 pm
by greasemonkey
M favourite anti theft device that I have seen is a limit switch fitted into the seat belt clip. This is coupled to a led on the dash(to show its working) and also to a relay which switches a fuel solenoid and the coil. No seatbelt, no go. Coupled to a delay - off timer it could work as an anti hijack as well.
Posted: Sat Jun 18, 2011 8:53 pm
by calooker
I can vouch for the simple cut out switch to the coil, it works. Many moons ago a girlfriend I had drove a old RWD Mazda 323. She lived in a flat that had no secure parking, after a couple of thefts and recoveries I fitted a cut out switch, they tried at least 4 times to help themselves, a couple of times they pushed the car down the road without much luck of getting it started. Also saved a Corolla I had this way.
