Donovan D
Has thanked: 148 times
Been thanked: 73 times
Post by Donovan D »
John Alves wrote: Thu Feb 20, 2020 9:20 am I see you fitted a steering damper, very good idea, my 58 Ghia wobbles all over the place when I hit a bump :(
The beam had the mounts on when I got it from FFR.
Didnt even realise that the early ones didnt have it.
Been thanked: 539 times
Donovan D wrote: Thu Feb 20, 2020 10:03 am
Made mounts for my 52 as it makes a hell of a difference in the ride, you feel safer at speed.
Donovan D
Post by Donovan D »
Things have been going slow.
Im busy with the steering shaft, box and tie-rods. Dave at FFR made me a new hub for the steering wheel as the one I got with the wheel was a bit bulky.
Should the inside of the steering shaft that connects to the steering box also be splined ? Im guessing it should be but not sure.
I can see spline marks on the inside but its definitely not as clean cut as on the steering box coupler. When the two are connected the shaft can be turned without the steering box turning and I can feel it moving over the splines, once all is tightened with the clamp and shoulder bolt it seems to be fine.
Splines in the part below?
Camshaft
Been thanked: 107 times
Post by Haans »
Don't believe so ,.....if my memory is serving me well. Splines on the steering box side,...which fits into the steering tube from the top. Pinched with the clamp and bolt
Me thinks
Haans wrote: Wed Mar 11, 2020 5:17 pm Don't believe so ,.....if my memory is serving me well. Splines on the steering box side,...which fits into the steering tube from the top. Pinched with the clamp and bolt
Me thinks
This man is correct, just tighten well and it cuts splines by it self.
Donovan D
Post by Donovan D »
Thanks Haans and Retro :hangloose:
Fitted the left side fender and finished off the wiring for the rear lights. Still need to do the running board on that side.
Riaan.N
Oil Seal
Been thanked: 38 times
Post by Riaan.N »
I like the sneak peek of the engine
Eugene
Has thanked: 59 times
Been thanked: 65 times
Post by Eugene »
Riaan.N wrote: Fri Mar 13, 2020 1:36 pm I like the sneak peek of the engineImageImage
Yea, I love the minimalistic approach :lol:
Donovan D
Post by Donovan D »
Very minimalistic indeed.
Busy busy busy...
So it seems the steering dampener bracket is in the wrong place with about 5cm.
Centered up the steering box, equal turns to each side and this is the result on the steering dampener, when turning left and right.
Donovan D
Post by Donovan D »
I was hoping to get the doors on and all the door parts assembled during this time. Our company went on lock down a week before the actual lock down started. Its business as usual for the wife and myself working remotely from home.
As luck would have it the 1/4 vent window rubbers are not correct for early beetles. Also battling with the door mechanism, seems the one I have is to worn out and dont release like it should.
I managed to redo the running board on the passenger side and fit the decklid. The decklid seems a bit warped and the fit is not 100%, I guess it can be expected from these old cars. Even fitting something simple as the bumper took a couple of hours as the empi brackets had to be slapped with the hammer.
Been thanked: 487 times
EMPI.... come on D - that car deserves better
acpaterson
Has thanked: 80 times
Been thanked: 131 times
Post by acpaterson »
Exactly. Dude!. EMPI????!!!
Herbie
Been thanked: 35 times
Post by Herbie »
Wow DonovanD. Rey nice project. Keep up the good work.
Neels
Neels
Blood Type: VW+
1978 Beetle SP 1600
1963 Beetle
Eugene
Post by Eugene »
Yea....Empi????
Donovan D
Post by Donovan D »
The rear bumper and bumper brackets are empi. Ja ja ja, until I find a good rear bumper it is what it is. I had the rear bumper rechromed and also painted the brackets.
Front bumper is original and very straight.
Plodding along and doing what I can during this period.
