Page 22 of 37
Posted: Wed Jan 24, 2018 6:09 am
the disc shouldnt move in relation to the caliper, so if it clears, that should be good enough. I'd say 1mm is fine, hopefully others can chime in.
The adapter will need to be trimmed down to clear. Easy on a lathe - your fathers lathe should work for this if he still has it.
Posted: Wed Jan 24, 2018 9:22 am
Make sure you are using well fitting half thread bolts so that it can not move around in the hole.
Normally they supply you with a location bolt on the one side to stop the bracket from moving under braking.
If not, you can make a threaded tube and take up the clearance space around the bolt.
Posted: Wed Nov 07, 2018 10:51 am
by Donovan D
Posted: Wed Nov 07, 2018 10:54 am
Very nice work, keep it up
Now that its summer again, the garage is a better place to bee....
Posted: Wed Nov 07, 2018 2:21 pm
really looks good
Posted: Wed Nov 07, 2018 2:38 pm
by Terry Phillips
All the pieces bits and pieces when it comes together you will be one proud man keep it up.
Posted: Wed Nov 07, 2018 8:28 pm
by fourier
Looking good Donovan!
Posted: Wed Nov 07, 2018 11:09 pm
by jolas
cool
Posted: Thu Nov 08, 2018 6:52 am
by Donovan D
Posted: Sat Nov 10, 2018 6:22 am
by Simmy
Great work on the bodywork!
Although I'm not one to comment on speed of projects, at least progress continues to occur... And once it's done and looks amazing, then hardly anyone (including yourself) will even pay attention to that anyway.
Posted: Tue Dec 04, 2018 10:12 am
by Donovan D
Posted: Tue Dec 04, 2018 10:14 am
Looks good, you can be proud.
What a differences a few hundred hours make....
Posted: Tue Dec 04, 2018 12:42 pm
by Jdt1976
Good progress.
Are you going to replace the “J-Strips” that takes the rubber that seals the bonnet and bootlet?
Posted: Wed Dec 05, 2018 7:34 am
by Donovan D
Jdt1976 wrote: ↑Tue Dec 04, 2018 12:42 pm
Good progress.
I wasnt to fussed about it but now Im thinking I should try and get them on.
Are there any local places that sell these strips ?
Posted: Wed Dec 05, 2018 10:59 am
by Jdt1976
Not sure if someone local got them.
I get them from Virtanen.
https://restorationpanels.com/product/j ... and-hoods/
You just take the primer off at the places you going to weld so now after primer is the right time to do it.
