Convert to electronic ign
- Facebook: Stefan De Koker
Had any one converted the standard ignition point distributor to a electronic distributor? I have the the Golf setup in mind. Can it be build over into std ac distributor?
- hitlers revenge
- Been thanked: 36 times
Re: Convert to electronic ign
I am running elctronic ignition in my Ghia, but don't ask me how it works.
I will ask my son to tell you all about it.
- What model do you have?: 68 Variant 69 Beetle
- Been thanked: 24 times
I run a wasserboxer electronic distributor on Petrus in conjunction with the Golf electronic control module and a Golf electronic ignition coil.
What a difference. The engine is smoother while trundling along in traffic, idles smoother and pulls better throughout the rev range.
- JamesD
- Been thanked: 20 times
I went for the pertronix kit into an 009. Starts easily, runs and revs smoothly. easy install but probably a bit pricey....
From fastest to slowest:
'75 SP 1600 with a few mods
- John Alves
- Has thanked: 3 times
- Been thanked: 48 times
Beamish Buggies in Cape Town use modified Golf ignition on all there buggies
http://www.beachbuggy.co.za
1958 1600 TP Karmann Ghia
1968 1600 TP Beamish buggy
1968 1500 SP Beetle
1968 1500 SP Beetle
- Bratjie
- What model do you have?: 74
- Facebook: https://www.facebook.com/juan.buter
- Been thanked: 5 times
I got this with my wasserboxer, any idea where it's from and what's needed to run it in my Turbo Beetle?
Excuse the hi-jack
Excuse the hi-jack
Esté robusto, ser fuerte!!!!
73 Beetle project
73 Beetle project
- eben
- Site Admin
- Been thanked: 54 times
That's a distributor...Bratjie wrote:I got this with my wasserboxer, any idea where it's from and what's needed to run it in my Turbo Beetle?
Excuse the hi-jack
That will work just fine and just bolts into place.Bratjie wrote:I got this with my wasserboxer, any idea where it's from and what's needed to run it in my Turbo Beetle?
Excuse the hi-jack
If you are going the turbo route, I would imagine that you will be using fuel injection.
I have found the Gotech ProX to be a very suitable controller as it can adjust the timing to compensate for boost and adjust the injector cycle to compensate for increased fuel requirements.
- Bratjie
Grapjaseben wrote:That's a distributor...Bratjie wrote:I got this with my wasserboxer, any idea where it's from and what's needed to run it in my Turbo Beetle?
Excuse the hi-jack
73 Beetle project
73 Beetle project
- Bratjie
I will be running a Dell 36 with boost sensitive rising rate fuel regulator, not too keen on locking a dizzy at 24 deg as some guy's suggested, what controller will be least expensive but also suitable to adjust timing during boost?jmvv wrote:That will work just fine and just bolts into place.Bratjie wrote:I got this with my wasserboxer, any idea where it's from and what's needed to run it in my Turbo Beetle?
Excuse the hi-jack
73 Beetle project
73 Beetle project
- Bratjie
Similar in form to the original except for the plug and internals, hope this help's,
73 Beetle project
73 Beetle project
I have a spare wbx distributor if anyone is interested. Doesn't have a cap or rotor.
- Has thanked: 4 times
- Been thanked: 98 times
Made you a offer on it after you claimed it was 100% working, you accepted the offer but never bothered to follow up ?????Blitzkrieg wrote:I have a spare wbx distributor if anyone is interested. Doesn't have a cap or rotor.
How could you have made me an offer on this when I only picked this up last week??!calooker wrote:Made you a offer on it after you claimed it was 100% working, you accepted the offer but never bothered to follow up ?????Blitzkrieg wrote:I have a spare wbx distributor if anyone is interested. Doesn't have a cap or rotor.
