Red Line
Posted: Thu Jul 07, 2011 11:23 pm
by stew 89
Quick Question
Does any one know what the Rev-limit on a standard type 4 2000 is? and when i say standard I mean solid lifter and 1800 heads and standard cam?
Many thanks
Stew
Re: Red Line
Posted: Fri Jul 08, 2011 7:06 am
by Muderick
HI Stew
If memory serves me...
The Kombi 2l Owners manual states:
51.5 kw
4200 rpm max
143 n.m torque
94mm bore x 71mm stroke
Muds
Re: Red Line
Posted: Fri Jul 08, 2011 8:47 am
by eben
It depends on what rotor you have installed. Type 4 engines come with a rev-limiting rotor and the limit is stamped on the bottom of the rotor if I remember correctly. But 4200 is OEM i think.
This one is 5400rpm
Re: Red Line
Posted: Fri Jul 08, 2011 11:54 am
by louisvr45
and the type 1 tp 1600? 4500?
Re: Red Line
Posted: Fri Jul 08, 2011 11:57 am
by Muderick
Nope...
1600 TP
35-37 Kw
4000 rpm
Re: Red Line
Posted: Fri Jul 08, 2011 12:51 pm
by louisvr45
muderick, in the manual it states:
37kw @4000rpm DIN
45kw @4000rpm SAE
whats the diffrence or meaning of the din and sae?
Re: Red Line
Posted: Fri Jul 08, 2011 2:12 pm
by Muderick
" Horsepower (or "HP") is the unit of measurement that describes the power of engines in various machines. However, there are various types of horsepower measurements, including the DIN HP (a version of horsepower that is measurement protocol in Germany) and SAE (which is the standard definition of horsepower).
While the two measurements are close, the difference is enough that it must be calculated "
Re: Red Line
Posted: Fri Jul 08, 2011 4:21 pm
by stew 89
Thanks guys very helpful.
