Looking for - 1600 gearbox
Posted: Thu Jul 14, 2011 8:43 am
by Rooikat
Yup, my beetle decided that she did not like her current one and broke it. So I need to find a replacement.
Re: Looking for - 1600 gearbox
Posted: Thu Jul 14, 2011 8:46 am
by louisvr45
whats wrong with your gearbox?
Posted: Thu Jul 14, 2011 2:11 pm
by Bratjie
Pm'd you,
Posted: Fri Jul 15, 2011 9:34 am
by Bratjie
Have a gearbox lying aroung, selector shaft at rear looks bent and casing broken, rear casing can be removed, can post pic's if anyone is interested.
Posted: Fri Jul 15, 2011 11:57 am
by louisvr45
yes can you post pics?
is it a late or early beetle gearbox?
Posted: Fri Jul 15, 2011 12:09 pm
by Bratjie
Think it's a late box, what's the distingiushing criteria? I will post pic on Sat morn,
Posted: Sat Jul 16, 2011 12:24 pm
by Bratjie
Where would I find a serial number? If this box is not good enough please see my post in "wanted - Body & pan" there are three cars all with boxes still in them if your'e interested, haven't driven any of them but they should be good. Let me know, you'll see in the pic's what I mean by the selector shaft and housing.
Posted: Sat Jul 16, 2011 9:27 pm
by Rooikat
I think the guy said it was the selector shaft that broke. They guy that sold us the beetle never put oil in the gearbox
She was running since December last year. We did not worry about it cause there where no leaks and the engine was in such a horrible state that we focused on getting her running more than anything else. The good news is that we got the gearbox running again. But it is not a permanent fix more like a "boer maak 'n plan" kinda deal.
Posted: Sat Jul 16, 2011 10:10 pm
by Bugger
Bratjie wrote:Where would I find a serial number? If this box is not good enough please see my post in "wanted - Body & pan" there are three cars all with boxes still in them if your'e interested, haven't driven any of them but they should be good. Let me know, you'll see in the pic's what I mean by the selector shaft and housing.
This looks like a late model box
Check opposite side of where you fit oil onderneath there will be stamped codes LEtters
Loui that seems like the right donor for you so I can build you a box if it is SFAS
Posted: Sun Jul 17, 2011 10:38 pm
by louisvr45
@Bugger will the selector shaft on my AS and the SF gearbox be the same?
and the gearbox mountings?
is it the same?
@ bratjie, You have a pm.
When can I come to have a look?
Posted: Mon Jul 18, 2011 9:19 am
by Bugger
louisvr45 wrote:@Bugger will the selector shaft on my AS and the SF gearbox be the same?
is it the same?
You need to use the bus selector housing and selector shaft and all the bus mountings when fitting the beetle box or RGB`s and swop the diff around
Posted: Mon Jul 18, 2011 9:31 am
by louisvr45
Bugger, so I can use the sf box with my old selectorshaft and selector housing.
I know you have to swop the diff around to have 4 fwd and 1 rev gears because of rgb's
Is the final drive/diff on both the same ? or does it differs?
Posted: Mon Jul 18, 2011 9:56 am
by Bugger
louisvr45 wrote:Bugger, so I can use the sf box with my old selectorshaft and selector housing.
Diff ratio is longer on the SF and yes yes to all the other Q`s
Posted: Tue Jul 19, 2011 11:38 am
by louisvr45
Bugger, do you know what the std gear ratio is the sf gearbox?
How do one use your application/ excel spreatsheet when calculate the speed at specific rpm with you reduction gearbox?
