Twin Solex Carb Kit for T1
Posted: Thu Aug 25, 2011 8:10 am
by calooker
34mm Solex Brosol carb kit from Brazil, all new, everything you need, it's 100% bolt on for T1 motor Bus, Bug, KG.
Exacly the same thing as our SP beetles had just slightly larger 34mm instead of 32mm. R4300
Similar kit is also available for T4 motors 1.7 to 2.0
Rui 082 830 6493
Can ship to anywhere in SA R90
http://aircooledvwaddiction.com/albums/album34/aag.jpg
Re: Twin Solex Carb Kit for T1
Posted: Thu Aug 25, 2011 12:29 pm
by Sambabus
Oooh,those are nice!
Posted: Fri Aug 26, 2011 2:08 pm
by 65beetle
One day when I'm big and strong...
Posted: Fri Aug 26, 2011 2:47 pm
calooker wrote:34mm Solex Brosol carb kit from Brazil, all new, everything you need, it's 100% bolt on for T1 motor Bus, Bug, KG.
Rui 082 830 6493
Hi Cal,
Please measure the carbs for me, want to fit to T4 motor in Fastback body with cover.
Also, tell me what the manifolds are made off, should I want to cut and shorten them for the 2L type 4 motor.
If they are weldable......
Posted: Fri Aug 26, 2011 2:53 pm
by calooker
The manifolds are ally for both T1 & T4 but the T4 manifolds in the kit will be too long to get the lot under the lid, I have a set of short 1700 T4 manifolds that sure will help but the air filters in the kit are too tall to make it work.
Posted: Fri Aug 26, 2011 3:07 pm
by slak
HI Rui what is the price on the t 4 kit ?
Posted: Fri Aug 26, 2011 4:22 pm
calooker wrote:The manifolds are ally for both T1 & T4 but the T4 manifolds in the kit will be too long to get the lot under the lid, I have a set of short 1700 T4 manifolds that sure will help but the air filters in the kit are too tall to make it work.
Please measure the hight of the two, carb & manifold, separate as well as together, and will you split up the kit or not.
maybe it will work by cutting and welding short manifold, and fitting a different air cleaner.???
Posted: Fri Aug 26, 2011 9:42 pm
by louisvr45
is it the solex 34 pic3 carbs? Like fleetlines came out with?
Posted: Fri Aug 26, 2011 10:01 pm
by calooker
louisvr45 wrote:is it the solex 34 pic3 carbs? Like fleetlines came out with?
No, look at the pic I attached. T4 kit R4500. Sorry can't break up the kit, can't measure manifolds for T4 this kit is T1
Posted: Mon Sep 30, 2013 8:38 pm
by Pharco
Hi Rui,
Do you sell carb rebuild kits for Solex Brosol 32/34 PICT 3? I have two carbs for 1969 Fastback that I want to rebuild but cant find carb kit.
Thanks,
Phillip
Posted: Tue Oct 01, 2013 7:49 am
by calooker
Do your carbs have 5 or 6 bolts bolting the carb top to base? A pic. will help.
