A great idea for front speakers in a Beetle
In Car Entertainment
How coooooool 8) is this?
Gary0302 wrote:This speaker enclosure may seem a little out there for some, but it works for me. It has been fabricated out of 2 each 4” PVC 90 degree bends, which is attached to a ¼” steel T-shaped bracket so that it can be mounted under the dash. The speakers are 6” West Marine speakers; I chose these because they are white and they match the PVC. Upholstery foam has been inserted between the speakers to help separate the channels.
The U-shape of this enclosure allows it to wrap around my Sirius Radio component. There is abolutely no interference with pedal operation or leg room.
The PVC parts included 2 of the 4" 90 degree elbow bends, along with a 4" (PVC diameter) straight piece cut down for the center splice, and 2 pieces cut so that they can be slipped into each end. These 2 pieces were needed because the speaker mounting screws would have ended up just on the inside edge of the elbow bends. After marking the locations of the screw holes, I used a Dremel tool to create dimples so that the drill bit would not travel over to the seam.
The bracket was fabricated from 2 pieces of 1/4" steel, one piece was 4" x 6-1/4", with a second piece measuring 4" x 4". The pieces were welded together to create L shape measuring 4" and 4". The mounting bolts are 4 each 1/4" x 1-1/2" stainless steel, with 2 each 1/4" x 1". The longer ones are used for mounting the PVC to the metal bracket (the top front bolts also double as mounting bolts from the bracket to the dash).
To be totally honest, the sound is very, very good, better than I expected. Please let me know if you have any questions, it would be my pleasure to share the details with anyone that is interested.
bugspray
Floorpan
Has thanked: 24 times
Been thanked: 16 times
Re: A great idea for front speakers in a Beetle
Post by bugspray »
Soooo cool. And cheap lol.
COOL IDEA .......... That mounting bracket must be heavy, way over kill.
Drusky
Has thanked: 77 times
Been thanked: 15 times
Post by Drusky »
I like this, it's simple, easy to do and tidy. I would use neodynium magnets to attach the speakers to the bug.
bugspray
Floorpan
Post by bugspray »
What are neyowhatyousaid magnets drusky?? I'm looking at a total dash customisation for a media instal... Looking at all angles for now.
vader
Post by vader »
Then bugspray you should get TonyZ to show you pictures of the sound in the front of Angrrr!
Drusky
Post by Drusky »
bugspray wrote:What are neyowhatyousaid magnets drusky?? I'm looking at a total dash customisation for a media instal... Looking at all angles for now.
Wiki is your friend:
http://en.wikipedia.org/wiki/Neodymium_magnet
You can get them locally:
http://neodymium.co.za/
I've used little flat circular ones to hold the wings on my slope soarer!
I think I bought from these guys:
http://www.magnetech.co.za/neodymium.htm
Just a thought......... :roll: .
Extremely powerful magnets next to a good sound system, is not a good idea..... :oops:
As the speaker magnets give you sound, and your strong magnets takeeath away........ :shock:
bugspray
Floorpan
Post by bugspray »
Cool thanks. Will ask TZ. And thanks Drusky will look into it. But Retro does make a reeeaaally good point.
Drusky
Post by Drusky »
Rare earth magnets, aren't from Krypton. They're not that powerful! Make sure they're not within 100mm of any electronics. To avoid scratching paint on mounting a strong magnet you can use a sheet of that cellphone screen protection stuff.
