PCD on split busses
didi
Been thanked: 37 times
PCD on split busses
Post by didi »
did all split busses have the same stud patren?
I suppose so - 5 x 205 mm, like that of a Beetle? Even the early Bays had it, before they went over to front disk brakes.
Merlin
Has thanked: 20 times
Been thanked: 39 times
Post by Merlin »
I'm not entirely sure, but afaik, all German buses were the same, so you're good to go.
N.
didi
Post by didi »
Let's say there's a splitty with a smaller PCD where does that come from? Would it be possible to fit bay drums?
HIGHLY unlikely...
Merlin
Post by Merlin »
You can fit Bay' drums, but I'm told it involves some mucking about with mods on on or both ends.
Why would you want to? I don't believe there'd be any substantial benefit to be gained.
N.
Merlin wrote:
any substantial benefit?
...disk brakes up front, for example?
didi
Post by didi »
It's not for my bus, just one that I saw
Yes, all splits, and in fact all buses built between 1950 and 1970 have the same wide five stud pattern.
It is not too difficult to fit bay brakes to a split: the front discs need a custom mounting plate, and the rears slide right on to the split axle; just need a spacer.
Merlin
Post by Merlin »
Didi's asking about "drums" Pine. :mrgreen:
N.
didi
Post by didi »
I can only go and see the bus tomorrow night, i'll let you know what's potting.
