Recovering the Black Rhino (pic heavy)
Posted: Mon Feb 27, 2012 10:21 am
so due to peer pressure(Jolas & Klaus) i now post this story ....(Jolas&Klaus sounds like a nice dealership name...
snorkel in the air...hence the name rhino
i bought my black single cab fleetline wide-body bakkie a year ago...the problem was that it was built in between two walls, blocked in by some other VW wrecks and had no rear suspension and gearbox...so this meant we had to drive to JHB strip the Gearbox and rear suspension from the crashed fleetline panel van i had also bought and get the bakkie on wheels in order to winch it out of the tight spot it was in
we started off by stripping the panel van first....
got the gearbox out and then to fit it in a space where no one had set foot for 20 years !
spiders..etc..the biggest problem was lack of space and uneven ground..the gearbox and suspension can get fcuk heavy when you have to lift it in a confined space believe me .. the jack kept on sliding on the rocks and once you are in there and the gearbox slips off the jack...you have no where to move out the way !
after many swear words...almost throwing in the towel a few times and loads of sweat and bumps on the head, we managed to get the box in and the wheels on !!
the worst was over...we then fastened my portable winch to the nearest tree and slowely pulled the bus forward...we couldn't get to the driver side front wheel so this was flat and rotten...so steering was a bit of a challenge being so close to the wall !
this branch caused many bumps on the same heads and if there was a chainsaw nearby it would have been gone !!
Once clear of the wall we could get the 4x4 in to pull it further out the way over very rocky terrain !
note the drivers side wheel...how stuffed it is !
to my surprize we found this little roof rack(with a VW sign on it) lying upside down under the leaves on the back.
once the bus was out she rolled very easy up to clear ground where we will prep. her for the transport guys to pick her up
and bring her down to PE
and that was our 2 day bus rescue mission in Krugersdorp and another bus saved from scrap metal
