Complete motor with all tinware ,carbs ,airfilters , clutch and pressure plate
motor running , no oil leaks
R3700.00
Midrand , Roland 0712984893
2000 type 4 motor
Piet
- What model do you have?: type 3, Porsche 550
- Been thanked: 15 times
Re: 2000 type 4 motor
I see you posted it a while ago, is the engine still available?
How much bigger is the Type 4 block than the1600? I'm building a 550 spider and I have limited space available (engine in front of gearbox, behind seats)
low82
- What model do you have?: 76 bay dc
hi
do you know if this motor will go into a 76 bay crew cab ?
if so i would be interested
