KTS customs new stock
Posted: Tue May 15, 2012 8:58 pm
Hi guys i have received my first shipment prices are as follows kevi082 478 0448 or zuniad 0829392744
Gear shift extension bug R120 Gear shift extension bus R149
Pop out frames ali only R399 each
S/steel mirror arms R199 set Harp mirror arms s/steel R320
Bus rubber kit h/brake pedals clutch R199
3 Bow roof rack s/steel R6500 ladder s/steel sold R2000
2 Bow roof rack s/steel R5926 Gasket set door handle 64-68 bus R60
Fuel tank neck seal R60 Bus licence seal R50
Door check rod seal R30 set acc pedal bracket R55
Deluxe trim black inserts R6500
Handbrake extesion T2 R 406 Porshche alloy style nuts R22 each
Bug rack R 2900 Kombi door pckets 575.34
turn signal seal bay R35.46 Bellows dip stick seal R35.46
Safari window kits R6k stainless steel waitng hardware should be here in a few days
