Aircooled VW South Africa • Tapatalk Android/iDevice/BB/Win App - Page 2
Page 2 of 5
Re: Tapatalk Android/iDevice/BB/Win App
Posted: Fri Aug 23, 2013 5:36 pm
by eben
brianj wrote:I upgraded to 3 and it was crap. Went back to 2. Is 4 better?
I think so Brian... Anyway you can play around with it, on Android, for 15 mins and request refund if you don't like it.
Posted: Mon Feb 10, 2014 10:54 am
by eben
Steady increase...
Posted: Tue Feb 11, 2014 8:20 pm
by beetle786
Easy to use on I phone
Posted: Tue Jan 31, 2017 8:21 am
by Riaan.N
Hi Eben,
Is there a known problem currently with Tapatalk? All my other subscribed forums on Tapatalk are working, but for some odd reason ACVWSA just stopped working a week or so ago.
I have removed ACVWSA and added, also deleted Tapatalk and reinstalled, but it did not work.
Tapatalk seems to be the big kahuna for mobile forum particiaption and reading, are there other decent alternatives?
Thank you
Riaan
Posted: Tue Jan 31, 2017 4:18 pm
by Piet
I sent Eben a PM about the same problem. Latest version of Tapatalk just seem to be full of k@k
Posted: Tue Jan 31, 2017 7:26 pm
by brianj
Ja me too, can only see new posts. Not unread or subscribed. On Android
Posted: Fri Feb 03, 2017 1:53 pm
by eben
I just saw the issue you describe now..... I'll see if I can get to the bottom of it...
Posted: Fri Feb 03, 2017 2:00 pm
by eben
Tapatalk will be fixing it in their next release:
https://support.tapatalk.com/threads/em ... abs.35069/
Posted: Tue Feb 07, 2017 9:21 am
by eben
Hi guys! They sent me a fix. Tapatalk should be working as expected again now.
Let me know if you have issues still.
Cheers.
Posted: Tue Feb 07, 2017 10:04 am
by brianj
yes its working now, Thanks Eben
Posted: Tue Feb 07, 2017 10:51 am
by eben
brianj wrote:yes its working now, Thanks Eben
No problem :hangloose:
Posted: Tue Feb 07, 2017 3:21 pm
by Riaan.N
It's working! Thank you Eben!
Posted: Fri Feb 10, 2017 8:47 am
by acpaterson
Eben, whatever changes have been made of late, it's messed up the forum. thats why there are double posts appearing. After posting a thread, or replying, it doesn't go back to the thread and SHOW your last post, ot seems to go back to the screen with your post there, as if it hasn't submitted it. Or, it goes to a blank screen. Need to do a refresh\resend and then you see your update in the thread.
Also, something's happened on embedding things like quotes, or images.. There's lines appearing through the code tags etc.. The forum's gone a little quirky of late.
Posted: Fri Feb 10, 2017 9:00 am
I am mostly getting the same issues as Alan. After every post the site just hangs.
Instead of hitting refresh, you can click on the address bar and press enter - that way it goes to the post instead of trying to repost what you entered.
Posted: Fri Feb 10, 2017 9:06 am
by eben
acpaterson wrote:Eben, whatever changes have been made of late, it's messed up the forum. thats why there are double posts appearing. After posting a thread, or replying, it doesn't go back to the thread and SHOW your last post, ot seems to go back to the screen with your post there, as if it hasn't submitted it. Or, it goes to a blank screen. Need to do a refresh\resend and then you see your update in the thread.
YOu mean straight through the browser and not tapatalk right?
