Page 2 of 3
Re: 2.0 8v golf engine in 1600 beetle
Posted: Wed Sep 26, 2012 3:27 pm
by dhjmarais
Actually I want to build a toy so I will do a lot of robot to robot dices. Do you think a 1600 box will last?
Posted: Wed Sep 26, 2012 3:32 pm
by dhjmarais
Actualy I want to build a toy so I will do a lot of robot to robot dices? Will a standard 1600 box last?
Posted: Wed Sep 26, 2012 5:45 pm
by dhjmarais
i actually want a day to day car but once in a while want to dice robot to robot. Will a stock 1600 do the job. I won't abuse the box like hard shifting. What kinda problems did you experienced ricky
Posted: Thu Sep 27, 2012 1:32 am
by RICKY-R69
My son is using my car at the moment. So it gets hammered some times. A lot actually. The 1300 box is actually better for robot to robot dices. Up until now the gearbox holds up perfectly. I just got one rule. No wheelspinning. That is the thing that breaks gearboxes. As for difficulties experienced- mostly growing pains.
Posted: Thu Sep 27, 2012 7:18 am
by dhjmarais
If you do 120km/h, what is your revs? Also what rediator are you using ang what starter
Posted: Thu Sep 27, 2012 7:57 am
by RICKY-R69
Got a 1600 golf radiator up front with a 12" fan. Keeps temp at 90 degrees. Revs at 120, just above 3000 rpm. As I am using modified beetle flywheel I am using the standard beetle starter. Think it is the same with a Gilo adaptorplate.
Posted: Thu Sep 27, 2012 8:34 am
by dhjmarais
What type and size pipes did you use from radiator to engine.
Posted: Thu Sep 27, 2012 8:42 am
by RICKY-R69
25 mm galvinised pipes welded to the pan. No overheating issues.
Posted: Thu Sep 27, 2012 8:49 am
by dhjmarais
Do you use a standard or upgrade/performance clutch
Posted: Thu Sep 27, 2012 9:03 am
by RICKY-R69
Standard Beetle clutch. Here is the link to my projects thread.
http://www.aircooledvwsa.co.za/viewtopi ... 23&t=23592
Posted: Thu Sep 27, 2012 9:24 am
by dhjmarais
Is it possible to fit the vw411 or 412 box and front disc brakes into a beetle
Posted: Thu Sep 27, 2012 10:05 am
no
Posted: Thu Sep 27, 2012 10:24 am
by RICKY-R69
Tony Z wrote:no
Like I said; anything is possible if you have the knowledge and resources. But why go through all that trouble while disc brake kits are available. 411/412 gearboxes are IRS so I agree with Tony Z. No
Posted: Thu Sep 27, 2012 10:41 am
Posted: Thu Sep 27, 2012 3:09 pm
by dhjmarais
Oh ok kwl. Do you know how much a disc brake setup will work out
