Some left over aircooled bits
Get your parts here
These are still available.
Split bus parts
Drag link R450
Steering rod adjustable with new tie rods R630
Steering rod non-adjustable with new tie rods R490
Steering damper OEM (Cofap) R360
Steering damper Brasil R250
2x Front wheel cylinders left & right Varga OEM R240 each
1x Rear wheel cylinders Varga OEM R240
2x Wiper blades OEM R170 each
Front indicator bulb holder set 62-67 R490
Front indicator lens seal set 62-67 R220
Inner cargo door handle 52-67 R80
Fuel cap 61-71 R150
Bell housing to body seal R100
Outer door handle seal set 64-67 R90
Bay bus parts
Fuel sender unit 73-79 R435
Front indicator lens amber 72-79 R110
Chrome door mirrors left & right R190 each
Indicator lens seal set 68-72 R220
Outer door handle with keys R190
Accelerator cable R80
Ignition switch (elec) 68-71 R210
Ignition lock with key 68-71 R300
Beetle parts
Lower door pillar hinge complete replacement pannel both sides OEM R210 each
Lower door pillar outer skin replacement pannel both sides R115 each
Indicator lenses front, clear & amber 60-66 R90 each
Wiper blades 50-57 R350 set
Eyelids chrome R140 for a set
Outer window scrapers both sides 65-79 R980 set
Inner window scraper both sides set R450
Fuel cap 61-67 R150
Rui 082 830 6493
vader
Re: Some left over aircooled bits
Post by vader »
Do you have a set of Pan bolts and nuts incl the spacers of a bug. The ones that hold the body to the pan?
Golfmad
What model do you have?: niks
Been thanked: 9 times
Post by Golfmad »
Hi Rui
Is that fuel sender unit, the float thingymajig inside the tank that I can just hook up to my original fuel guage? If its the complete unit, I needs it !
vader wrote:Do you have a set of Pan bolts and nuts incl the spacers of a bug. The ones that hold the body to the pan?
Nope, sorry.
Sambabus
Short Block
Has thanked: 39 times
Post by Sambabus »
Il take all the split bus parts except the indicator bulb holders, if you can wait until pay day.
Sambabus wrote:Il take all the split bus parts except the indicator bulb holders, if you can wait until pay day.
Whatever is available at the time you can take.
sean
Has thanked: 63 times
Been thanked: 228 times
Post by sean »
Hi Rui
I will take the following for the split bus if still available.
2 x Wiper blades @ R170each
Fuel Cap - R150
PM me bank details with additional postage costs to Somerset West.
Will take it immediately.
Sean
