Oil temp sensor and gauge
Posted: Wed Mar 13, 2013 11:50 am
by John Alves
Hi all
I'm thinking of adding a oil temp sensor to my newly acquired 1600 (fresh build from Calooker) motor
Is it worth it, or am I wasting time and money?
Re: Oil temp sensor and gauge
Posted: Wed Mar 13, 2013 12:27 pm
by calooker
I hate guages, they make me worry too much.
Posted: Wed Mar 13, 2013 12:57 pm
calooker wrote:I hate guages, they make me worry too much.
Thats true. But sometimes it is needed.
I wouldnt bother with the temp sensor on a 1600 if you dont go racing. Check the temp of the dipstick occasionally until you are happy it is OK.
If you burn yourself, oil is too hot (can happen when the engine is running in). If you can hold the dipstick for a second or more, then temp if OK.
Posted: Thu Mar 14, 2013 6:38 pm
When I have had work done on a VW motor, I used a long glass thermometer, into the dip stick hole for the 1st week, to see the temp of the engine.
When happy, its running right, I replace it back with the dip stick.
Now I have a temp. logger with two sensors, so now I am really Posh.
(had to get one for my work)
But whats good for the cats a$h, is also good for the VW motor....
Posted: Wed Jan 23, 2019 2:34 pm
by Batman
Tony Z wrote: Wed Mar 13, 2013 12:57 pm
While I'm driving ..... asking for a friend
Posted: Thu Jan 24, 2019 9:10 am
by 73type2
retrovan wrote: Thu Mar 14, 2013 6:38 pm
But whats good for the cats a$h,....
Herman!! What are you doing to your cat?? Should I call the SPCA on you??
