indicator in headlight
beetle786
Camshaft
Post by beetle786 »
has anyone fitted an indicator in the headlight of a 68 beetle or later...like the 60s bug i think.
4029
Has thanked: 424 times
Been thanked: 542 times
Re: indicator in headlight
If your beetle has a sloping glass, it can be done very easy, either by changing the park light to an orange lamp with holder and moving the park to the side and drilling a new hole.
If you have a upright light but the reflector and globe type, then you can do the same as the system above.
Only if you have a sealed beam, or semi sealed beam where it would be near impossible.
Why I say near impossible, is you can on the semi sealed, dill hole with sharpened masonry drill, into the glass and fit a fitting, or remove the silver on the inside of the glass on a certain spot, and fit the globe behind the semi sealed beam, and shine through the back of the glass, have seen it done, but :bn: load of work with little reward.
beetle786
Camshaft
Post by beetle786 »
so not really worth it then indicators on bumper would be better.can a golf indicator fit a beetle bumper fitting .
4029
riaanj
Been thanked: 41 times
Post by riaanj »
I saw an advert in either Ultra VW or VolksWorld of a month or two ago, right on the last page that had 7" headlights with orange L.E.D's in them for the turn signal, the add was from CIP1..
Just keep on BUGGIN'
T6 Ranger 2.2TDCi D/Cab
307E Anglia panel-van
Honda CBR600RR
Honda CBR600F4
bugspray
Floorpan
Has thanked: 24 times
Been thanked: 16 times
Post by bugspray »
The golf indicators don't have the curve to fit the bumper! I tried, :( it does fit but not flush.
beetle786
Camshaft
Post by beetle786 »
where can i get the right ones from or does anyone have any .
4029
