Page 1 of 2
VW Logo blank keys for sale
Posted: Fri Jun 21, 2013 3:14 pm
by Muderick
Good day Volks
I have a few Beetle and Bus VW logo blank keys (not spoken for yet) on short order. These keys normally sell for anything from $25 - $75 depending on what you are looking for, without postage cost to S.A.
I will have the following keys available for you by next week Friday 28 June, at R200 each, posted anywhere in South Africa.
* 2 X VW Bug Beetle Volkswagen key blank logo SE profile 1960
* 2 X VW Bug Beetle Volkswagen key blank logo SC profile 1961 -1966
* 2 X VW Bug Beetle Volkswagen key blank logo SV profile 1961 -1966
* 2 X VW Split OR Early Bay Bus Type 2 Volkswagen key blank logo L profile 1967 -1970
* 2 X VW Split Bus Van Type 2 Volkswagen key blank logo T profile 1964 -1966
Pre-order yours now, and make payment next week when I have them. If you do not find your year model, let me know your key code or year model and I will get them for you on the next order. Your key code is either a 1, 2 or up to four letter code found on the door handle or Ignition.
If you do not have the original emblem key that came with the car bearing the key code, the key code for 68>79 Beetles can be found on the outside door handle, open the door, remove the phillips screw behind the door seal in line with the handle, move the handle forward and out, the code is on the ear with the screw hole, see picture below check both handles for matching codes,
67-70 beetle ghia type 3 11K001 thru 72K110 bus 11L001 thru 72L110
71-79 beetle ghia type 3 11M001 thru 72M110 bus 11R001 thru 72R110
Key code for 1967 and older beetles can be found on the outside door handle, open the door, remove the 2 phillips screws behind the door seal in line with the handle, move the handle forward and out, the code is on the lock button retainer, the not chrome part, example code for 61 should be SV123, check both handles for matching codes, SG, SC 001 thru 240 SU, SV 001 thru 630 SE 1 thru 750
The 1967 and older ignition switch will have the code on the ear touching the body where the mounting screw is. Unscrew the screw from under the dash, go into the trunk and turn the switch up to see the code, it may be rusty or dirty and you may have to clean it. 68-79 bus: the easiest place to find a code is the sliding door lock. 68-73 has the key in the handle. The handle is removed by a screw behind the door panel in line with the handle where it pivots. The code number is stamped on the square shank, example 23L046. You may have to clean some grime to see it.
Once you have them just have your local locksmith copy and cut it from your code or current original or replacement key.
These keys are nice, even if you have a logo key already, or not, or just to add it as a spare logo key.
Muds
0829941643
Re: VW Logo blank keys for sale
Posted: Fri Jun 21, 2013 4:17 pm
by raw
split bus will have code by Monday for you.
Posted: Fri Jun 21, 2013 5:08 pm
by Terry Phillips
Muds I have a 60 Beetle that does not have a ignition switch can one buy the ignition switch that will have the same code as the door or will I have to fit a universal switch and get a coded key for the door.
Posted: Sat Jun 22, 2013 1:42 am
by Muderick
No worries Rory
Terry I will see if I can find an ignition switch for you. Just double check your code on the door handles and let me know what they are.
Muds
Posted: Sat Jun 22, 2013 10:18 am
by Terry Phillips
Muds the code for drivers door lock is SC 63, the left door does not have a lock,
thanks.
Posted: Mon Jun 24, 2013 9:04 am
by Crewcab71
Im keen on a key for an early bay....
Posted: Mon Jun 24, 2013 10:39 am
by Muderick
Rory, let me know when you are ready with your code
Terry, I will reserve 1 x SC key for you
Baron, I will reserve 1 x L key for you
I assume you guys are all taking 1 key each, correct?
Muds
Posted: Mon Jun 24, 2013 12:51 pm
by Terry Phillips
I want 0ne but what do I do about my ignition switch,do you think you can get one if so how much.
Thanx
Posted: Mon Jun 24, 2013 2:34 pm
by Crewcab71
yes, 1 key for me.
Posted: Mon Jun 24, 2013 5:07 pm
by Friedrich
i will take 1xSV blank please
thanks
Friedrich
Posted: Tue Jun 25, 2013 8:08 am
by jahjuan
Hi Daddy, :D
Second L key for me if still available? I have a 67 which will need this.
Posted: Tue Jun 25, 2013 10:59 am
by Muderick
LOL@ Juan!! "L" key for you!
Marwaan has your radio in his boot OK?
All other requests have been noted, will update later.
MUds
Posted: Wed Jun 26, 2013 7:58 am
by jahjuan
Thanks Dad. :P
Got the radio yesterday, love the giftwrap! My grandma always used brown paper for all presents, so brought back a bit of memories tearing it open.
I'll transfer money in the meantime, should have your details still.... Unless we can put that adoption through and I save on the key. :P
Posted: Fri Jul 12, 2013 10:12 am
by Muderick
Hi Volks
The VW logo blank keys arrived and are ready to be posted to you.
Send me your postal address and then please make payment if you have not done so yet to:
POP can be sent to [img]muderick.kamalie@vodacom.co.za%20or%200829941643[/img]
M Kamalie
Nedbank
Paarden Eiland
Acc: 2092155504
Br: 109209
Taken:
Jahjuan x 1 "L" key (paid)
Friedrich 1 x "SV" key
Terry Philips 1 x "SC" key ....I hope to get your SC Ignition switch by Monday or Tuesday as well.
Crewcab71 1 X "L" key
Raw 1 x "T" key
Still available:
2 x SE keys
1 x SV key
1 x SC key
1 x T key
Regards
Muds
by Muderick
Hi Volks
M Kamalie
Nedbank
Paarden Eiland
Acc: 2092155504
Br: 109209
Taken:
Raw 1 x "T" key
Zax 1 x "T" key
Still available:
2 x SE keys 1960 only Beetle
1 x SV key 1966 Beetle
1 x SC key 1961 - 66 Beetle
Regards
Muds
