beetle gboxs, front beams, rust engine
Posted: Mon Jul 15, 2013 6:06 pm
hi all
I have 2 front beams, and 2 gearboxes laying around, R250 each
(one of each is still attached to a pan that is rusted, and has a hold cut into the tunnel at the pedals, if you take the box and beam you get this pan for free
on wheels)
The motor is completely rusted, and does not turn by hand. Dirt and leaves and water have been going in the carb. Has distributor and leads, and a generator.
Its fitted with stainless trumpets, one is cracked on j bend and will need welding. I'add with it a 2nd set of trumpets too.
I'm guessing if its stripped it might have some usefull spares R400.
Fuel tank, no sender R150
Pm me if keen, i'll mail pcs
Dbn north area
Dbn north area
