Page 1 of 3
V8 Nightmare 2.1 WBX Turbo in Beetle
Posted: Thu Sep 05, 2013 8:05 pm
by Bugger
Thought I will post a Pic or 2 of the 2.1 WBX turbo Motor we are building for a Client
We have fitted I beam connecting rods and Special built for us from Germany Wossener Forged pistons that we fitted in the motor as well
The Beetle is still under construction but have a peep
Re: V8 Nightmare 2.1 WBX Turbo in Beetle
Posted: Thu Sep 05, 2013 8:27 pm
by Blitzkrieg
Very nice, love the waterboxer motors...keep us updated
Posted: Thu Sep 05, 2013 9:51 pm
by beetle786
like the exhaust pipes. good one
Posted: Thu Sep 05, 2013 10:31 pm
by Ron&Gill
beetle786 wrote:like the exhaust pipes. good one
Why?
Posted: Thu Sep 05, 2013 11:20 pm
by beetle786
Ron&Gill wrote:beetle786 wrote:like the exhaust pipes. good one
Why?
they just tacked in place and the real tail pipe exits to the
side of the exhaust box .is that correct pierre.beetle still
looks like it has the std exhaust system though if one looks
at it at a distance.
Posted: Fri Sep 06, 2013 1:19 am
by Ron&Gill
Ja, I can see that. But why, why not just use the tail pipes out the back...
Posted: Fri Sep 06, 2013 5:11 pm
by beetle786
Ron&Gill wrote:Ja, I can see that. But why, why not just use the tail pipes out the back...
personally i would close up the valance and use
just the one tail pipe . With that exhaust setup no need for the
others anyway .
Posted: Fri Sep 06, 2013 10:06 pm
by Bugger
Why Why Why
Coz I can
it just gives that extra confusion to the un educated when they see the twin pipes
But Spoke to the Client which is a Good guy as his name is also Pierre
and we might close the cut outs and smooth out the back valance with the hidden Tailpipe
One of the Big reasons why I always hide the real tail pipe on a conversion like this is when the bug is low then the tailpipe always catch thorough every driveway you go
Posted: Fri Sep 06, 2013 11:25 pm
by Ron&Gill
But why don't you use the twin tails for an exhaust, then the low single pipe won't be needed and it won't catch on any driveway. Why, why? Oh WHY??
Posted: Sat Sep 07, 2013 2:13 pm
by Bugger
Ron&Gill wrote:But why don't you use the twin tails for an exhaust, then the low single pipe won't be needed and it won't catch on any driveway. Why, why? Oh WHY??
These Dutch just dont Get it
in SA there is not someone that will be able to build a proper twin outlet performance pipe
But I know Ron is just taking the Piss out of me
Posted: Sat Sep 07, 2013 6:58 pm
by Ron&Gill
I'm not really taking the piss, well, a little, but the question is a genuine one...
Looks to me like you almost built a proper one right there, Bugger... One hole to close and another one, or two, to open...
Posted: Sun Sep 08, 2013 9:43 am
by Bugger
Ron&Gill wrote:I'm not really taking the piss, well, a little, but the question is a genuine one...
Two to close and one to open
as said the client want the tailpipe cut outs closed and the tailpipe not to be seen
Posted: Sun Sep 08, 2013 12:35 pm
by Ron&Gill
I saw that. But I still don't have an answer to my question... Say the client had said, "Yes, I do want the two rear ones to be the real exhausts and I want you cut off and close the one that catches on the driveway, and here is lots of money for it... Lots!" What could/would you have done?
Posted: Sun Sep 08, 2013 2:06 pm
by RICKY-R69
Let's see. Say you have a water tank that you want to drain. Which will drain it faster? One two inch pipe or two one inch pipes? You would have to increase the size of the two tailpipes, that it would not look stock anymore. All about airflow through the silencer!
Posted: Sun Sep 08, 2013 2:54 pm
by Ron&Gill
Sorry, but kak! Those two tail pipes are not the same as stock peashooters. In fact, they look each the same as to one waiting for driveways. Therefore, you can get 4 times the flow through those two than you can get through the one (it's a quadratic equation, by the way...). It is about the flow through the silencer, but not volume, is my guess.
