My 1975 1600 S Beetle project - Her Oberst
Posted: Sun Nov 24, 2013 11:22 am
This is the story of Her Oberst:
After years of searching for a SP beetle, without luck, I bought a 1975 1600S. mainly because an army buddy, JP Perold got one just before our 2-year national service ended.. and I also loved the S.
I bought it in Stilfontein from a gentleman who claimed to have spent thousands on it to get it road worthy for his son to drive to Potch and back...
The trip to bring the car back home started with a fill-up and suddenly the car was leaking fuel in front... it turned out that the breather pipe was cut of.... well, that was little worries.. the 200Km trip to Centurion started OK, but 30Km other side of Potch, the power suddenly dropped... and we could manage 80Km/h... OK, still little worries.. bring him home... that was all that counted.
So far I have:
fixed the screw that keeps the points fixed - the old one was stripped and caused the points to closed... power loss problem found..
replaced dissy cap
new spark plug leads
new spark plugs
drained the oil... awesome that the car could run on that black tar mix though...
cleaned carburetor
there was a chafing noise from the fan... that took a Saturday to strip inlet, dissy, carb and fuel pump off to take out the fan and alternator.
I replaced brake switch on the master cylinder and the brake lights started to work again.
funny noise when engaging the brakes, turned out to be a missing brake shoe retention spring right front - brake pads looks new though...
checked left front brakes and it turned out that the inner bearing is not seating on the stub-axle the inner hole is 4 to 5 mm to big... current bearing 30602 should be 30505C... waiting for bearing man to open..
Some pics as I go along at:
Edit - I loaded pics in my gallery - I will number them as it will be easy to view them when sorting on file name. (Descending will show the latest pics first.)
Cheers
CS
So far I have:
replaced dissy cap
new spark plugs
cleaned carburetor
Cheers
CS
