AA mechanic fixes Land Rover with a potato
An AA mechanic has been branded a 'hero' after fixing a broken down Land Rover - with a POTATO.
Mario Papademetriou, 59, managed to mend the 50-year-old motor's failed ignition system by strapping a potato to the engine with cable ties and screws.
Mario, an AA patrolman, was called to a Hertfordshire farm to fix the 1960s vintage Land Rover, which was not starting because the ignition did not work.
The condenser, which is part of the ignition system on older vehicles, was broken, but since he did not have a spare one to hand, north-east London patrolman Mario decided to see if he could make his own one.
Mario was unable to tow the vehicle from the farmland, and needed to bodge a condenser to help it limp 12 miles to the nearest garage.
After his first attempt, using tinfoil and silicone repair tape, failed, he decided to get creative.
Mario said: "As the vehicle was on a farm, there were a lot of vegetables around, so I thought I'd try wiring up a potato with a couple of screws to act as a condenser.
"Amazingly, it started instantly, so I followed the member to the garage and he said the vehicle had never driven so well."
For his remarkable efforts, Mario won an internal AA competition to find the most original and inventive roadside repair.
Technical director Donald MacSporran said: "Our patrols work on pretty much any vehicle on the road and pride themselves on their ability to fix them.
"While they regularly go the extra mile with some very inventive repairs, we continue to invest in their training and equipment to maintain our leading fix rate.
"Although vegetables are best left on the dinner plate, Mario's use of a potato was definitely a chip above the others - an excellent example of thinking outside the box, or should that be sack."
The condenser absorbs the voltage spike as the points open and close when the key is turned, amplifying the spark that eventually starts the engine.
The potato worked because it was connected to the switching side of the coil, and absorbed some of the energy from the voltage spike, producing a reasonable spark that was able to start the engine.
An AA spokesperson added: "We were sceptical which is why we had to try it ourselves.
"The Land Rover we tried it on would not start with the condenser removed but started instantly the potato was connected to the coil switching terminal."
The potato isn't the only foodstuff that has been used to fix or run a car.
In the old days, a raw egg could sometimes be cracked into a car's radiator to seal a leak.
Chewing gum has also been used to temporarily fix a windscreen seal, while baking soda and warm water can clean battery terminals.
Re: AA mechanic fixes Land Rover with a potato
- VW-rules
- What model do you have?: '61 & '70 Buses
- Has thanked: 10 times
I've had a wheel bearing disintegrate on a bad Transkei coast "road".
I had spare bearings in my toolbox but no grease to pack them with so I used the butter in our camping fridge.
It got me 150Km home with no problems.
- Dam
- Flywheel
- What model do you have?: A few
- Been thanked: 7 times
A couple of years ago we went on the Bike SA Easter Desert run to Namibia, great fun!
On day one, just before Van Zylsrus, I noticed water dripping from the Syncro's radiator. We tried to get radiator weld or some sealant from the Co-op, but the Omie behind the counter told us to just get a packet of Rajah medium strength curry powder & put a spoonful or two in the water system. We drove through the Kalahari dunes to Namibia, Aroab, Koes, Gotchas, Stampriet to Windhoek. Windhoek to Swakopmund via the Khomas Hochland gravel road, played in the dunes, down to Solitaire & Sossosvlei, Maltahohe, Mariental back to Joburg. We checked the water level often and kept an eye on the temp gauge but we made it
I keep a packet of Rajah in my toolbox on (watercooled) trips.
- Sambabus
- Short Block
- Has thanked: 39 times
- Been thanked: 14 times
I repaired my broken pressure switch on the master cylinder with a paper clip, a length of wire, and a bic pen.
That potato trick il remember though
