Valve/tappet covers
Posted: Sun Apr 26, 2015 7:28 pm
I have just changed the oil in my 1600S. It was my mothers car and I suspected that it had not had an oil change in a long while. My suspicion was correct. When I took the oil drain cover off, it and the strainer were covered in a muddy oil/grease muck. I did the oil change and with a few km's checked under the car and found what appears to be a leak at the valve cover on the one side. It would appear that the previous oil was so thick that it wasn't leaking anywhere but the new oil has found somewhere to leak out.
I have looked up on you tube on how to change the gasket but everything sort of skips the removal of the cover so I need to know if I have to drain the oil before I remove the valve cover or if the oil doesn't reach that level when the engine is not running.
Secondly the covers are humingously rusty so I want to strip them and respray them. Anything to avoid when doing that?
Any advice will be welcome.
