Hi all
first time posting
Im in search of a beetle1600 twinport engine running condition
my engine siezed [emoji17] piston through the block something got stuck in the visco fan
Thanks a mil
Beetle 1600 twinport engine wanted
Re: Beetle 1600 twinport engine wanted
a location in your profile would definitely help... are you in SA or USA? city would help too.
My apologies Tony Z i am in S.A Jhb South will update my profile asap
Using Tapatalk
No need to apologize... it just makes it easier for us to help you. I am sure you dont want to buy an engine from CPT.
Depends on your budget... vdubtech build good engines, but they might be out of your price range. 2 failed engines and it would have been cheaper to spend more in the first place...
many "reconditioned" engines sell for 5k or less. I am one of the few who advocate the fact that a rebuild shouldnt cost less than 12K IF done properly. You simply cannot buy the spares needed for a proper rebuild for under 5K. Tha machining also costs close to 5k. So buying a rebuild for under 5K.... think about it.
Thanks for the advice and its is noted and taken into consideration... however im looking for a running engine to fit as i have someone interested in the beetle as long as its moving as much as im going to regret letting it go but i need the space and further reasons of letting it go.. hence i do not want to spend a bunch of cash on it and not get back what i put in it
Using Tapatalk
Vw oldie
- What model do you have?: A few
- Facebook: volksie
Hi there. I can assist
0848728745
Regards
0848728745
Regards
1957 Vespa Piaggio 3 wheeler
1958 Ratty beetle
1962 Beetle
1963 LHD Ragtop Beetle
1969 Single cab
1958 Ratty beetle
1962 Beetle
1969 Single cab
