Baywindow Kombi windscreen rubber - German - feeler
Hi Guys
I am putting this out there for now.
I can get original quality German windscreen rubbers for a baywindow kombi.
R850 excl postage to you.
These are MUCH softer than the locally available rubbers.
Would anyone be interested?
Anyone interested in other rubbers? Cargo door for example?
German or Brazilian?
Terry Phillips
- Has thanked: 193 times
- Been thanked: 121 times
Re: Baywindow Kombi windscreen rubber - German - feeler
Tony I would be inerested in the windscreen rubber and possably a few others.
- Has thanked: 425 times
- Been thanked: 543 times
Would be keen on Fleetline panalvan rubbers kit if you can get the German set.
- acpaterson
- Has thanked: 80 times
- Been thanked: 131 times
Tony,
Is softer "better"? I seem to see small water drops on the inside of my windscreen in the bottom corners, which seems to come through between the window and the rubber? I've probably got a crappy windscreen rubber in, so I'd take one if this is the recommended route to go.
Al
Al
- Been thanked: 322 times
I'd be interested in at least one windscreen rubber Tony, as well as the rear hatch rubber.
- Muderick
- Has thanked: 42 times
- Been thanked: 69 times
depending on price Tony... 3 for me please.
1. Rear window rubber for bay bus.
2. Rear hatch surround rubber for bay bus
2. Sliding door rubber for bay bus... 1972 RHD, sliding door on LHS
Muds
Muds
Old School or Bust!
- Derek
- Been thanked: 25 times
I'd take a windscreen rubber for a 71 Bay, as well as two sets of sliding door rubbers for the same model if the pricing is reasonable.
'70 Dormobile - 1.6
'76 Brasilia - 1.6
'76 Brasilia - 1.6
Wow, alright, here I thought one or two people would be interested and the rest would say its too expensive, you can get cheaper at pro-auto.
I need part numbers. I'll go through my books to see what I can dig out, but if you have VW numbers lying around, please put them up here so I can get prices for the right items.
softer is definitely better. Once the rubber ages, it gets hard and then it doesnt seal as well anymore.acpaterson wrote:Tony,
Al
OK, here are some part numbers that I have found. If someone can confirm these as correct???
Engine lid seal / deck lid seal- 211 827 711 C
Left cargo door seal - 214 843 791 B
Windscreen seal - 211 845 121 D
Rear windscreen seal - 211 845 521 D
Door seal left - 211 831 721 D
Door seal right - 211 831 722 D
Rear door seal / tailgate seal - 211 829 193 E
I'll get pricing if you guys are happy with part numbers.
- Derek
I use the Pro Auto window rubber, and as Alan Patterson reported, because the rubber is so hard, at the bottom corners the water makes its way inside under the glass and into the cab on some of my kombi's if the fit is not 100%.
The sliding door rubbers are not available from Pro Auto to my knowledge. Their door rubbers can sort of work, but are not ideal.
'70 Dormobile - 1.6
'76 Brasilia - 1.6
'76 Brasilia - 1.6
Terry Phillips
Tony I would like a price on a kit OEM 211898129 I hope its the one.
If you can also do a Beetle then price pls on 111845122.
Thanks Tony
Thanks Tony
- Klaus
- Has thanked: 13 times
- Been thanked: 11 times
Same for me.fig wrote:I'd be interested in at least one windscreen rubber Tony, as well as the rear hatch rubber.
I am waiting for prices...
Terry Phillips
Tony if the kits are a problem then I will take a windscreen rubber for a Early Bay.
I have been promised prices next week sometime
