Hi Guys,
I am trying to figure out what year/trim/motor my VW Low light D/Cab Bus is and am struggling to figure out how to go about that
I really hope you can help as I want to restore her as close to original as possible
The vin plate (found behind the drivers seat) reads as follows
268N9774
EA 300
03/57/57
The chassis # (which I found stamped onto the chassis in the engine bay)
2612236402
This appears to be conflicting info – if I look at the 1st 3 x numbers
Vin plate would imply that it is a type 2, pick up 1968
But the chassis # implies that it is a type 2 pick up 1971
Does this mean that there was maybe a “body swap”? Which appears unlikely as there are no obvious signs of tampering when you look underneath the car
The engine # doesnt really help either as it looks like this was from an "aftermarket afterthought"
Any help would be appreciated
Cheers
Gerard
What Year is my Bus?
- What model do you have?: T2 DCab Low Light
- RikusVisser
- What model do you have?: 1969 T2 Westfalia
- Has thanked: 12 times
- RikusVisser
Re: What Year is my Bus?
Try this link:
Worked perfectly on my bus but something is wrong with that VIN of yours
http://vw-mplate.com/mcode.php
- Been thanked: 322 times
Your VIN is for a 1971 pick-up. The third digit of the VIN (post-1965) tells you model year. The second digit tells you it's a pick-up, but that is all.
The 268 that is confusing you is the model number and has no reference to the year. 268 is double cab pick-up, right-hand drive, rear door on left.
Oh, and welcome to ACVWSA Gerard. Please don't forget to tell us a bit about yourself in the New Members thread, as requested in your welcome mail.
