Autovilla motor conversion
HippyPete
What model do you have?: Kombi
Post by HippyPete »
Hi guys, am a newbie here, hoping to get some advice. I'm looking at fitting a 2L golf motor in an autovilla, here's a few questions I have;
1) what is the prefered motor to use, 8v/16v, which series (2/3/4), efi/carb?
2) should I can the std auto box? If so, what is a good replacement, and who could make the adaptor plate?
3) what would be a good radiator to use, and in what position? ( have a lot of pattern making and fibreglass experience, so building stuff is not a prob.)
4) what disc brake conversions are locally available?
Looking at doing as much of the work myself.
Thanks, looking forward to hearing from you guys.
Re: Autovilla motor conversion
How about posting photo's of your bus, and why you want to fit a water cooled motor, give more info, and we will be glade to share info with you,
We will all be speaking the same thing then.
sean
Has thanked: 63 times
Been thanked: 227 times
Post by sean »
Why do you want to fit a motor from a Golf?
Autovillas also already have disk brakes, why do you ask?
HippyPete
Post by HippyPete »
Will be picking it up next we, bought it as a project, and thus not running. ( motor in pieces).
I' m planning on travelling a bit with it and would like it to be able to tow a trailer with 2 road bikes, so need a little more power than std, don't really want to go the whole V6 route.
Already has disc brakes? Great, never knew.
Appreciate the feedback, thanks guys.
slak
Has thanked: 7 times
Been thanked: 32 times
Post by slak »
Hi welcome to
ACVWSA and owning a vw
U should get in contact with Pierre from Vdubtech they do a lot
of Golf conversions but also do very nice Aircooled rebuilds and he is Great with
Gearboxes and Advice
Vdubtech 011 822 2799
U Only Live Once Right !!!
sean
Post by sean »
I would never even consider towing anything with a Golf, so putting an engine like that into a much bigger car is going to be even more underpowered. You will be disappointed with a Golf motor in there. If you want towing power, what about a Lexus V8 if you are quite sure you want to hack it for a watercooled conversion?
splitfan
Has thanked: 46 times
Been thanked: 26 times
Post by splitfan »
I am a big fan of the 2.0 8v Golf conversions , running a injected setup with mp9 is super reliable , engine power is more than enough for towing but gear ratios might be a issue. There is allot of info online reg this . Since you don't have a location listed its a little hard to refer you to someone in your area .
HippyPete
Post by HippyPete »
I'm in Mpumalanga.
HippyPete
Post by HippyPete »
HippyPete
Post by HippyPete »
Here's some pics guys. Am going up to Joburg tomorrow, and will drop by Pierre at Dubtech, and see what the way forward is getting a good motor and gearbox in there. Anybody got an idea where I can find new/good lights and lenses from?
Derek
What model do you have?: 1971, 1972, 1978
Facebook: Derek Antonio Serra
Been thanked: 25 times
Post by Derek »
I hope you don't need rear lights and lenses mate - I'm pretty sure they are nearly impossible to find for an Autovilla. Front lights and lenses from Volkspares...
'70 Dormobile - 1.6
'76 Brasilia - 1.6
Terry Phillips
Has thanked: 193 times
Been thanked: 121 times
Zambia
Post by Terry Phillips »
Google Gilo engineering and look at all the conversions you might get some answers there. Just remember lots of the engines are now out dated and a camper fully loaded with a trailer with bikes you are going to need to make the right choice first time round so do your homewok first.
HippyPete
Post by HippyPete »
Derek, unfortunately the rear lenses are in terrible co nd, although not broken, they faded and cracked up. Will make a silicone mold, and cast a new set in casting resin.
kingpeanut
What model do you have?: autovilla
Post by kingpeanut »
Hi HippyPete
What did you decide?
andyrtmorgan
What model do you have?: '59 Ghia Coupe
Post by andyrtmorgan »
Hi guys, any final decision on the best engine to fit to an Autovilla? Quite tempted to get hold of one and do it up as a holiday vehicle just don't want to use up all my leave getting to my destination!
'59 Ghia
