Limited Slip Diff
Posted: Tue Jul 03, 2007 10:33 pm
by Corp
I am looking at installing a limited slip diff.
I know it has been done before but I don't know which limited slip diffs will work in the beetle nor where to get it.
If any person here knows could they please inform me and the rough price thereof. :arrow:
Posted: Wed Jul 04, 2007 7:04 am
by fig
A ZF LSD was a stock option on all ACVWs, but they're rare as hen's teeth, and apparently require a particular driving style.
It is possible to fit a modern LSD or locking diff to a Beetle/bus box, but all the workshops I have spoken to say it's not possible. :roll:
If you do find out anything, please share the info here, as I am also looking to fit a LSD to one of my buses.
Posted: Wed Jul 04, 2007 7:46 am
by 4agedub
First question, why do you need LSD?
Is the car a daily driver? If not, just lock the diff. Works like a charm. Makes your turning circle a little bigger, but other than that very nice. Eliminates a lot of wheelspin and helps for the inner wheel spinning though a high speed corner.
Posted: Wed Jul 04, 2007 9:27 am
by Blitzkrieg
4agedub wrote:First question, why do you need LSD?
What about a superdiff from the states? I priced one. +-R1500
Posted: Wed Jul 04, 2007 9:36 pm
by Corp
The car is in daily use so locking the diff is a big no no. I want the limited slip diff to increase handling ability especially when get those urges to take a quick corner or when I play off road sometimes.
I will look for the Superdiff but where is my best option to buy from? :arrow:
Posted: Thu Jul 05, 2007 9:24 am
by Blitzkrieg
Corp wrote:The car is in daily use so locking the diff is a big no no. I want the limited slip diff to increase handling ability especially when get those urges to take a quick corner or when I play off road sometimes.
Phone mike egan at thundersport and ask him for a quote on a SCAT superdiff..
Posted: Fri Jul 06, 2007 12:17 am
by Corp
Are the company details on the forum? :arrow:
Posted: Fri Jul 06, 2007 9:09 am
by Blitzkrieg
No, but here goes
Thundersport
31 Gillits Road
Pinetown
031 701 6304
031 701 6306
One is the phone number, one is the fax, not sure which is which though
Posted: Mon Jul 09, 2007 10:32 pm
by Bugger
First Q What do you want to spend on a LS diff
Can get from QUAFE LS diffs at a crayzeeeee price of roughly R6-8K
Yes the super diff is a much cheaper option if you read up what the clever Guys in the states say when one wheel start to spin it automatically transver the power to the other wheel to A CERTAIN degree
I have built 3 gearboxes the last month with super Diffs in mostly for racing purposes (Rotary Turbo`s) and Will guarantee You it does make a differince
Before used to see one wheel putting down rubber after fitting 4 spider
diff you see 2 tyre stripes on the road surface.
Me and Rui has actually ordered ond extra diff from the states Cost is roughly $165 X11.5 landed here in SA.
On My DC Microbus I used the center Portion of a Syncro box The diff standard is a 4 spider gear setup plus the advantage off engaging the lockdiff part with a Vacuum pump on the side of the Gearbox.
Corp in what car do you want to put this setup with what motor and is it
Swing Axle or IRS
Fig do you want this for one of your busses for better offroad capabilities Coz the Twin hand brake set up works good for being stuck in sand
ZF LS DIFF
Thought I took a pic of the super diff
Yust closed a box with my last one in Yesterday
Posted: Tue Jul 10, 2007 5:59 am
by fig
Bugger wrote:Fig do you want this for one of your busses for better offroad capabilities Coz the Twin hand brake set up works good for being stuck in sand
Yes, I want one for offroad use, especially those times where the bus's axle articulation is insufficient and it lifts a rear wheel. I have found the (single) handbrake quite useful for that, but often in those situations you don't have enough hands free.
How does one fit double hand brake levers in a bus?
Posted: Tue Jul 10, 2007 3:56 pm
by Bugger
To b honest havent done that to a bus before but I would say starting with a 2nd lever is a good start and modifi the floor to accomodete the 2nd lever and then u have a cable place make you 2 individual cables to soot one per hand brake
You make a latch to link both so u dont have to make both ratchet mechanisims to work so if you need one side seperate just unlatch them from one another and back again for normal handbrake
Wont say it is a afternoons work but some planning and one could make a nice system much cheaper than a LS Diff
Posted: Tue Jul 10, 2007 6:09 pm
by brianj
the cables are already separate, so all work is up front. will bugger the floor though.
Posted: Thu Jul 12, 2007 9:04 pm
by Bugger
Life is full of choices
But still can be done neate!!!!!
Posted: Mon Jul 16, 2007 11:33 pm
by Corp
The diff is to be used in a beetle with a newly aquired and relatively standard motor. It is a swing axle.
I see info has been posted for contact details for the SCAT superdiff. Will be sure to make use of it as soon as I can.
I have seen the twin handbrake mod before and I am not a fan. It works alright but I don't want to have to manually adjust brakes and etc to get traction.
Will let all know once I get the estimated quote.... :arrow:
Posted: Tue Jul 17, 2007 12:40 pm
I have a CB superdiff and HD sidecover sitting at home. Drop me a pm if you want it... brand new, as packaged from CB. Will check on the price if anyone is really serious
