Another one??????
Posted: Fri Apr 07, 2017 6:24 pm
by 64 Notchback
I have just swpped a motor cycle for a Kestrel beach buggy body :shock:.
Not quite sure what do do with it yet, I might use the chassis from the Spyder to build it.
Here are some pics.
Re: Another one??????
Posted: Fri Apr 07, 2017 6:28 pm
by 64 Notchback
by 64 Notchback
Posted: Fri Apr 07, 2017 6:29 pm
by 64 Notchback
Posted: Fri Apr 07, 2017 6:30 pm
by 64 Notchback
Posted: Fri Apr 07, 2017 6:31 pm
by 64 Notchback
Posted: Fri Apr 07, 2017 7:06 pm
by buggyfan
Very nice Thomas.
What bike did you swop ?
Posted: Fri Apr 07, 2017 7:23 pm
by 64 Notchback
It was a 125cc Honda estorm.
Bought it about 4 years ago for my son to get to college and back but thank heaven's he did not really like it so it just stood. I would sometimes use it to work.
Been trying to get rid of it for some time
Posted: Sat Apr 08, 2017 5:36 pm
by 64 Notchback
Today I decided to trial fit the Kestrel body to the pan. After spending the better part of the day grinding off rusted nuts and bolts I was finally able to separate the three parts and put them on the pan.
I also noticed that there is a small metal tag on the driver's side with a number stamped on it, could this be a production number?.
Some pics to follow.
Thanks for reading
Posted: Thu Apr 27, 2017 6:22 pm
by 64 Notchback
Today I decided to focus on the beach buggy so I took the body of and cleaned the pan.
While busy wire brushing I decided to give the pan the same treatment as the sand rail only a different colour
Will continue on Saterday doing the rest.
Before
During
Posted: Mon May 01, 2017 6:25 pm
by 64 Notchback
I eventually finished coting the pan and then decided to install the pedal assembly aswell.
Then discovered that the accelerator cable tube inside the tunnel is broken so I had make a plan.
Found a length of 3mm I D stainless tube and this will be attached to the outside of tunnel.
Thanks for reading
Posted: Mon May 01, 2017 6:30 pm
Good progress there... its coming together quickly - keep up the momentum
