After some finishing off touches mechanically, installation of the motor and gearbox, the bus is running lovely. If you take a look at the interior pics below, you will see its original paint and colour on the dash board, but at some point in its life, some guy resprayed it with a rattle can outside. It looks hideous, but im going to just try and flat it off and hopefully it will reveal the original paint underneath. The bus is in a lovely solid condition.
It still had the Zimbabwean plates on when I got it, the original owners had moved to South Africa in the early 2000's and drove it down. This is also not a locally assembled bus, but a full import.
Take note of the different instrument cluster, its a 69 model with the very early speedo with odometer at the bottom of the needle, but it reads in km/h.
