Anyone used a Car Capsule?
Jessescott
What model do you have?: 1970
Post by Jessescott »
Has anybody used a Car Capsule before? Any advice of it. Can you recommend one?
buggyfan
Long Block
Has thanked: 95 times
Been thanked: 87 times
Re: Anyone used a Car Capsule?
Post by buggyfan »
O boy google " 1957 plymouth belvedere time capsule "gone wrong Lol
buggyfan
Long Block
Post by buggyfan »
Car capsule ------ time capsule.....think werw on different pagea here lol
Jessescott
Jessescott
That's what I meant by a car capsule
Has thanked: 45 times
Been thanked: 208 times
Looks like a good idea to protect your car. Once the car is inside, draw a semi-vacuum, then fill capsule with de-hydrated air or some "friendly to the car" type of gas.
Jdt1976
Has thanked: 116 times
Been thanked: 90 times
Post by Jdt1976 »
My neighbor use them.
It blows the air through a filter so limits the dust. I would think you need a generator for when there is a power outage.
Will get more info from him.
If you are on a mission to stop rust, a capsule isnt really the right option in my opinion.
Remember, the official name for rusting is oxidation.
So the only 100% surefire way to stop rusting is to remove the oxygen.
This is why metal is painted.
OK, its a lot slower without water.
But now if you use a capsule, you will need to remove the humidity from the air before forming your bubble. Otherwise, the water will still condense (as if you left it in the air normally) as condensation is caused due to a temperature variation between the air and the vehicle (when the air warms up quicker than the car). It will then evaporate later in the day and then condense again the next morning, causing a continuous rust process until it runs out of oxygen.
What am I saying?
Basically, a capsule wont stop rusting unless you dehumidify the air prior to injecting it as Dawie recommended.
If you get a good quality, without leakage, you can fill it with Nitrogen.
But heat the Nitrogen as you fill, and you sould be OK.
