Setting play on steering box - Baywindow !!!
- Oil Seal
- Has thanked: 7 times
- Been thanked: 15 times
Hi All,
Need some help
How do one set the play on the steering box on a Baywindow ?
Will it be best to take the bus to a specialist ?
H
Need some help
H
- Been thanked: 322 times
Re: Setting play on steering box - Baywindow !!!
It's quite straightforward. But, before we go into that, why do you want to adjust the steering box? Have you isolated excessive steering play to the box? Generally, on VW buses, the steering box is the last cause of steering play. You should exclude all other possibilities before messing with the box. Many steering boxes have been wrecked by unnecessary overtightening.
First check:
Drag link
Steering centre pin
Suspension ball joints
Tie rod ends
Wheel bearings
Once all the above are confirmed within spec and you still have play, then adjust the steering box as follows:
Raise the front of the car
Loosen the lock-nut on the adjustment screw
Screw in the adjuster a quarter of a turn at a time, then turn the steering from lock to lock, feeling for any resistance
When you feel you've adjusted the play out, without causing resistance when the steering is not facing straight ahead, then tighten the locknut, lower the jack and drive the bus to test the steering. Do this test in an empty parking lot or elsewhere where you have enough space. Turn the bus full lock left, and release the steering, then repeat with full lock right. It should return to centre on its own from full lock both sides. If there is any resistance preventing a strong self-centring action, then the steering box is over-adjusted and you should back off the adjuster until the steering self centres easily.
In general, the steering box wears most around the centre point. Adjusting this wear out usually makes the box too tight off centre.
There is also a thrust bearing on the end of the steering shaft, inside the box, which can be replaced if worn. Some engineering shops can remachine the worm and nut if these are badly worn, but usually you need to replace the steering box at this point.
First check:
Drag link
Steering centre pin
Tie rod ends
Wheel bearings
- Oil Seal
- Has thanked: 72 times
I replaced everything Fig suggested and it sorted out my bus. I didnt need to adjust the steering box itself.
- No More Landy
- Has thanked: 23 times
- Been thanked: 6 times
That was quick.
1971 Beetle
2021 Polo tsi
2006 Defender Kalahari
2021 Polo tsi
- Has thanked: 141 times
- Been thanked: 100 times
- Oil Seal
Sorry I missed the joke......I meant I did everything that Fig suggested and it worked for me so if Spicydave does what is recommended it will probably work.
No More Landys was under the impression that you where Spicydave and had fixed all the things that Fig mentioned, between posts,brucet wrote: Fri Aug 11, 2017 1:10 pm Sorry I missed the joke......I meant I did everything that Fig suggested and it worked for me so if Spicydave does what is recommended it will probably work.
Was just a Miss-interpretation of who said what......and who DID what ....when.....
Rather funny from this side......
- AlanH
- Has thanked: 126 times
- Been thanked: 86 times
That's how I saw it as well.
Wanted parts:
Left sunvisor
Sink faucet
Left sunvisor
Sink faucet
- No More Landy
Sorry, I seemed to miss that it was a different person that fixed all the listed items.
My mistake - I just thought the same guy had done all those suggested repairs in a couple hours and reported back that problem was solved.
1971 Beetle
2021 Polo tsi
2021 Polo tsi
- freddiebooysen
- Been thanked: 47 times
Anybody that can suggest an engineering shop that can sort my steering box in Gauteng.
Or anyone that has one available that is till in good condition ?
- Has thanked: 78 times
- Been thanked: 37 times
Hi Freddie
I have one but am unsure of condition and will not be avail for a couple of weeks as it is still in the bay sc that we need to cut up.
