spacer for 1600
- Has thanked: 51 times
- Been thanked: 7 times
spacer for 1600
Can you use a 10 mm spacer plate between the gearbox and 1600 engine instead of shortening the spickot shaft ,i have the correct starter.
Re: spacer for 1600
the clutch wont work if you do that
