How much to renew rear part of floor pan
- No More Landy
- Has thanked: 23 times
- Been thanked: 6 times
While laying my VDO sensor cable I unearthed this nasty surprise despite the owner insisting bug was rust free.
How much will a new piece of floor panel and a panel beater cost me all in to weld up ?
Last edited by No More Landy on Mon Sep 04, 2017 11:36 am, edited 2 times in total.
1971 Beetle
2021 Polo tsi
2006 Defender Kalahari
2021 Polo tsi
Re: How much to renew rear part of floor pan
If thats the only rust you have then you doing good for such an old car.
Why not try Bugger , his banner is on top of each page here on the forum, if in JHB, or Grand Slam if in CT.
- No More Landy
Thanks. Any idea cost
1971 Beetle
2021 Polo tsi
2021 Polo tsi
- No More Landy
With original panel ?
1971 Beetle
2021 Polo tsi
2021 Polo tsi
- Oil Seal
- Has thanked: 7 times
- Been thanked: 15 times
nope with 1.6mm sheetNo More Landy wrote: ↑Mon Sep 04, 2017 2:35 pm With original panel ?
- What model do you have?: type 3, Porsche 550
Is that under the seat where the battery is? Then the damage might be caused by battery acid and will be very localised.
- No More Landy
No. Passenger rear footwell left sidePiet wrote:Is that under the seat where the battery is? Then the damage might be caused by battery acid and will be very localised.
1971 Beetle
2021 Polo tsi
2021 Polo tsi
- Donovan D
- Has thanked: 148 times
- Been thanked: 73 times
Have you checked underneath the car to look at the entire pan ?
Is the pan covered with rubberising ?
- No More Landy
Covered in ruberize yes. Going to sample more.
1971 Beetle
2021 Polo tsi
2021 Polo tsi
- Donovan D
If that is on the passenger side it might be worth inspecting the pan some more.
Although rubberising is good it can also hide plenty of rust.
I have poked off some rubberising on my kombi and there was just rot under it.
- No More Landy
So far under the battery is toast and the Passenger Rear Footwell.
Is it better to buy an OEM type foot-well panel or just get the panel-beater to install steel plate ?
1971 Beetle
2021 Polo tsi
2021 Polo tsi
Your car , your choice
If you want to keep value up, then fit the right panels, if you need it for transport for now and can do the repair at later stage, then fit a steel sheet.
OMO
OMO
- Donovan D
What Herman said, if you're not fussed about it then steel sheet otherwise get the correct pan sections to keep it looking original.
- Edmond
- Has thanked: 22 times
- Been thanked: 31 times
Correct pan sections were R800 for the rear quarter of the pan at FFR when I last found out 3 months ago, full halves were R2000.Im going to use steel sheet to replace mine just cant afford the R2000+ for a full half
