Push Rod Washer - Rear Suspension Beetle
No More Landy
What model do you have?: Beetle 1971
Has thanked: 23 times
Been thanked: 6 times
Germany
Post by No More Landy »
Is this washer made of rubber and where will I get it ? Called "Guide Ring" in my manual.
Trying to eliminate all knocking sounds from suspension and assume this is one source if this is missing from mine.
1971 Beetle
2021 Polo tsi
2006 Defender Kalahari
fourier
Has thanked: 31 times
Been thanked: 37 times
Re: Push Rod Washer - Rear Suspension Beetle
Post by fourier »
It's more like a hard plastic, with a lip below, which clips into the "guide for lever". A rubber grommet will be too soft, and quickly suffer damage from the push rod.
(o= i =o) (o\ ! /o)
hobb
What model do you have?: 73, 74, 77 busses
Post by hobb »
fourier wrote:It's more like a hard plastic, with a lip below, which clips into the "guide for lever". A rubber grommet will be too soft, and quickly suffer damage from the push rod.
You can import them, but for the meanwhile you can cut a piece of hosepipe , loosen the bottom nut and washer and slide it over the shaft.
Sent from my SM-G925F using Tapatalk
No More Landy
Germany
I was buying some Silicone Rubber at Rubber Mouldings and saw some fairly hard rubber washers/grommets the exact size I needed so bought two and slipped them in after removing the bottom nut and washer - found the genuine ones at R100 each but bought these two at R50 together.
1971 Beetle
2021 Polo tsi
